Thread started 22 Sep 2008 (Monday) 17:44
EOS 10D Shutter Problem?
Grinning_Giant
1 post
Sep 22, 2008 17:44 |  #1
My camera's shutter button seems to be causing a problem. About 70% of the time I have to hold the button down very hard or for about 2 seconds before the shutter responds and the photograph is taken. I have a BG-ED3 battery grip attached to the camera and when I use the shutter button on the grip it responds intantaneously, like normal.
It seems to me that the shutter button is wearing out, do you reckon my diagnosis is correct? Any tips?
spitfirejd
Sep 22, 2008 18:26 |  #2
Sounds about right. If you sent in to Canon they would replace the whole top of the camera.
Edit: I just noticed you have a 10D. The above assumes they still have the part for it.
Jeff
”Your eye must see a composition or expression that life itself offers you, and you must know with intuition when to click the camera. The Moment! Once you miss it, it is gone for ever.” Henri Cartier-Bresson
basroil
Sep 22, 2008 19:01 |  #3
Are you sure you aren't on one shot? If you are, then it may be that the focus mirror isn't up to spec and probably causing low keeper rate as well (assuming no user error on your part, and assuming you know well enough that in low light the camera will not get focus quickly and may happen even when there is sufficient light)
EDIT: Though the one to the top is the likely problem/solution, I'm just throwing other possibilities out there for you.
tpfoo
Sep 25, 2008 05:03 |  #4
If you half press the button too long there is a delay on shutter release. If not then probably a small button switch needs replacement. Not expensive and is pretty easy job.
デレック, 德瑞克, Derek
sando
Sep 25, 2008 06:54 |  #5
Just the button wearing out. The one on my older 20D is a lot less responsive than my 30D.
- Matt
1,368 views & 0 likes for this thread, 5 members have posted to it.
2761 guests, 133 members online
