Thread started 22 Sep 2008 (Monday) 18:42
Why is x-sync a camera feature?
Poe
Sep 22, 2008 18:42 |  #1
Can someone explain why the x-sync speed is a camera feature rather than a flash feature? I would assume that the speed at which the flash fires a burst that can be recorded by the camera would be a flash design parameter; in other words, the flash should be the limiting factor for sync, not the camera. If the 1D3 can have an x-sync of 1/500 with a 580ex, why can't the XT?
Nikon D750, D7200 | Nikon-Nikkor 14-24G, 60G Micro, 70-300E | SIGMA 35A, 105 OS, 24-105 OS | ZEISS Distagon 2.0/25 Classic, Apo-Distagon 1.4/55 Otus, Apo-Planar 1.4/85 Otus, Makro-Planar 2/100 Classic, Apo-Sonnar 2/135 Classic
Dream ­ Merchant
Sep 22, 2008 18:50 |  #2
I think it's because it's entirely dependent on the design and ability of the camera's shutter.
Editing welcome :D
Gatorboy
Sep 22, 2008 19:04 |  #3
Poe wrote in post #6360559 (external link)
Yeah, and why does a Porsche cost more than a Kia?
Dave Hoffmann
FlashZebra
This space available
Sep 22, 2008 19:13 |  #4
Read this carefully and you will understand the basic concept of a focal plane shutter, the inherent design, and the inherent design limitations.
http://en.wikipedia.or​g/wiki/Focal-plane_shutter (external link)
Enjoy! Lon
Titus213
Sep 22, 2008 19:13 |  #5
The sync speed of the camera is not the speed at which the flash fires. It is the maximum shutter speed that will allow the sensor to receive all the light from the flash.
Dave
Perspiring photographer.
DDCSD
GIVIN' GOOD KARMA
Sep 22, 2008 19:18 |  #6
The 1D3 can sync at 1/300s (with an EX speedlight, 1/250s with other flashes/strobes), not 1/500s. It can sync at 1/500s (all the way up to 1/8000s), when you turn HSS on when using an EX series speedlight (and some third party flashes). An XT can make use of HSS as well.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
Poe
Sep 22, 2008 20:50 |  #7
Correction...1Ds3
Poe
Sep 22, 2008 20:50 |  #8
Titus213 wrote in post #6360722 (external link)
I realize that. But why the different x-sync speeds between cameras?
Poe
Sep 22, 2008 20:57 |  #9
Gatorboy wrote in post #6360674 (external link)
You could have been more constructive in your reply.
Poe
Sep 22, 2008 20:58 |  #10
FlashZebra wrote in post #6360721 (external link)
Enjoy! Lon
Thanks! This explains its. It's more of a design issue of creating a FP shutter that can move extremely fast so as to allow the full sensor to be exposed by flash rather than a moving slit.
Titus213
Sep 22, 2008 21:07 |  #11
Poe wrote in post #6361272 (external link)
For the same reason some shutters are rated at higher actuations I would think - material and design. The higher end cameras have better material and design? Shooting film for years I had 1/60 and then it jumped to 1/125 and it was a big deal. Now at 1/250 (20D) it's really good. And with high speed sync to my cameras max of 1/8000 I'm happy.
Dave
DDCSD
GIVIN' GOOD KARMA
Sep 22, 2008 21:07 |  #12
Poe wrote in post #6361268 (external link)
Correction...1Ds3
The 1ds3 only syncs at 1/250s. You are probably thinking about the original 1D, which is spec'd to sync at 1/500, but actually can technically sync at any speed, due to the fact that it uses an "electronic shutter" instead of a conventional shutter. Since there is no actual physical shutter in it, there is no shutter to "creep" into the image, thus the sync speed is not mechanically limited.
Derek
Poe
Sep 22, 2008 21:19 |  #13
DDCSD wrote in post #6361370 (external link)
Ooooh...I mixed up a different shutter speed I saw on the specs with the x-sync for the 1D3. The x-sync is 1/250 I see upon review.
gkuenning
Joined Jan 2005
Sep 23, 2008 04:59 |  #14
Roughly speaking, the flash itself is instantaneous (typical electronic flash durations are 1/1000 to as short as 1/100,000 second).
Because the flash is so brief, it illuminates only the part of the sensor that is exposed to light at the moment it fires. The shutter must open fully, exposing the entire sensor; then the flash must fire before the shutter starts to close.
Focal-plane shutters get their higher speeds by moving a slit across the sensor. Above the X_sync speed, there is a never a time when the entire sensor is exposed.
Some flashes have a "high-speed sync" mode in which the flash fires several times as the slit moves, so that you wind up with even flashes across the sense. This feature isn't normally very useful, though.
Turning for a moment to history, old bulb flashes for one-time use took a long time from when they were fired (literally, ignited) until maximum light output. To keep up with Curtis N's famous maxim of having the flash go off while the shutter is open, they actually had to fire the flash before the shutter started moving. You'd have perhaps 1/10 of a second in which the flash reached full output, followed by a 1/60 exposure with essentially constant flash output. Then you'd thrown the bulb away with no concern for the fact that it was toxic waste. :-(
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
René ­ Damkot
Sep 23, 2008 06:16 |  #15
There is, but it doesn't do much more then "protect the sensor from dust"... Fastest speed it does is 1/125 or 1/250s or so... Faster speeds are done by switching the CCD on and off like you say.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
2,038 views & 0 likes for this thread, 8 members have posted to it.
1503 guests, 136 members online
