Thread started 24 Sep 2008 (Wednesday) 11:05
1D Mark III Users: Great Camera Setting Tip
MichaelAlan_Photo
Sep 24, 2008 11:05 |  #1
Hell friends,
I just wanted to let you all in on a little tip that I found with the Mark III and how it is capable of making your life a whole lot easier.
If you know about it then good for you. If you don't then try it out...
This is primarily for the photographers who like to assign the '*' button for their auto focusing over those who just press the shutter half way.
The feature that helps me get the shot 10/10 times is that I have my AF set to the AF-ON button on the back right and I have the * set to a registered camera setting. I move my thumb to the * when I don't have time to adjust my manual settings so it just jumps into Av mode with +1/3 EC so I can always get the shot and get it exposed in the ballpark. As soon as I release it it back to normal Manual mode. The * button also does the AF as long as going into Av mode.
I have my Mark III set up as follows:
cFn. IV - 1: Shutter Button/AF-ON button = Set this up with what you do in mind. The main thing here is to assign the AF-ON button to do all the Autofocus action. I don't have my camera near but I think I am set to 0 or 3. Who knows.
cFn I - 14: Apply Shooting/Metering Mode = Enable.
I registered this to put me into Av mode with + 1/3 exposure compensation. This means that every time I press the * button, my camera will not only auto focus, but it will also jump into Av mode with +1/3 exposure compensation. No need to fidget with my settings. All I need to do is move my thumb from the AF-On button to the * and I am in Av mode to ensure that I get the shot. You can assign this button to whatevr you want really. Program mode, Tv mode whatever!
Finally (optional)
cFn. IV - 2: AF-ON/AE Lock Button Switch = enable to switch their functions so you are back to AF with the * and the AF-ON will activate the registered camera setting.
This is open to interpretation and isn't perfect for everyone. If you think it would be helpful then give it a shot and let me know what you think.
my portfolio: www.michaelalanphoto.c​om (external link)
my fine art site: www.michaelalanfineart​.com (external link)
let me inLIGHTin you: www.inlightinworkshop.​com (external link)
SoaringUSAEagle
Daddy Of The Crop
Sep 24, 2008 11:37 |  #2
Thanks for the tips :D I just took a look into 1-14 and that is pretty spiffy. I havent read up on all the custom functions but that is really handy.
5D4 | 50 1.4 | 85L II | 24-70L II | 70-200 2.8L IS II
Lazuka
Sep 24, 2008 11:40 |  #3
MichaelAlan_Photo wrote in post #6371886 (external link)
Hell friends,
Finally (optional)
I literally got my camera 5 days ago, so this is a great tip, i'll be playing with it tommorow.
I suck at Photoshop.
MichaelAlan_Photo
Sep 24, 2008 12:26 |  #4
Glad it can help. Just like GI Joe said, Knowing is half the battle.
The other half is remembering that you have this nifty feature enabled!
nicksan
Man I Like to Fart
Sep 24, 2008 12:53 as a reply to  @ MichaelAlan_Photo's post |  #5
I feel more comfortable with AF assigned to the "*" button, but I can certainly see the benefit of this.
MichaelAlan_Photo
Sep 24, 2008 13:31 |  #6
nicksan wrote in post #6372581 (external link)
That is why God gave us this feature:
It will switch their purposes. So your AF can be back to the * and the Av mode will be on the AF-ON button. See above again which explains that feature.
nicksan
Man I Like to Fart
Sep 24, 2008 13:46 |  #7
Yep, have had the "*" for AF for a while now...don't ever need to switch to Av but for those who do, I can certainly see this as a great alternative.
MichaelAlan_Photo wrote in post #6372875 (external link)
Savagelogic
Joined May 2004
Sep 24, 2008 15:10 |  #8
Thanks a bunch for the tip, this will be very useful assuming I remember that I set this up out in the field!
elbirth
Joined Jul 2003
Sep 24, 2008 15:47 |  #9
That's actually very cool.
I have a question, though... would the cFn I - 14 happen to be available on any of the other series cameras? Specifically, the 5D. I'm assuming the fact that the 5D has a dial might make that a no (plus you have the custom modes that could perform essentially the same function), but wanted to ask anyway. Would be handy to avoid having to turn a dial if you have 2 modes you alternate between a lot.
5D Mark II, Leica M8
Canon EF 24-70mm f/2.8L USM, Canon EF 70-200mm f/2.8L IS USM, Canon EF 50mm f/1.8, Canon EF 100mm f/2.8 USM
POTN Strap, Domke J3 bag
Doublea17
Sep 24, 2008 15:48 |  #10
Michael,
thanks for the tip when I get mine:) on Monday (hurry Up UPS) I will try them setting.
____________
1D Mark IV,1Ds Mark II, 1D Mark IIn,
300 2.8 IS L, 70-200 2.8L IS II, 24-105 L, EF 40 2.8 STM,
Mr. ­ Clean
Sep 24, 2008 16:45 |  #11
cFn I - 14 is one of the most underused but best CFN's on that camera.
Mike
some shots @ Zenfolio (external link)
TeeTee
Sep 24, 2008 19:29 |  #12
I found that out some time ago and it's a real lifesaver in fast changing situations. It's a shame it isn't publicized more because it basically allows you to work in two modes at the same time with no lag in between.
Good job pointing this out to the masses, it's been mentioned before but every now and again it helps having a refresher :)
5DmkII & 85L
and a bunch of other glass that rarely sees the light
datadump
Sep 24, 2008 23:32 |  #13
thx for the tip..
datadump
datadump
Sep 25, 2008 07:25 |  #14
when u set it up in this way, too bad u cant change the aperture value too... like press * and scroll the top wheel to increase/decrease a/v
datadump
MichaelAlan_Photo
Oct 29, 2008 10:56 |  #15
datadump wrote in post #6377593 (external link)
I would consider this a beggars can't be choosers setting.
What I mean by this is that you will get a shot that is no worse than one stop over / under exposed.
If you shoot in RAW then this should be no skin off your back. Would you rather miss the shot entierly?
11,600 views & 0 likes for this thread, 17 members have posted to it.
1460 guests, 137 members online
