Thread started 25 Sep 2008 (Thursday) 02:05
Anyone here notice benefits of RAID 0 and transferring large number of files?
lsquare
Sep 25, 2008 02:05 |  #1
I'm considering adding a second hard drive and a RAID controller to have a RAID 0 setup. The problem is that I'm not sure if I will notice any performance gain in the real world. How many of you guys consider a RAID 0 setup to be essential when dealing with large files?
ben_r_
-POTN's Three legged Support-
Sep 25, 2008 09:52 |  #2
RAID 0 will give you an increase in HDD write speeds, however if you referring to the transferring of data from your CF card to your HDD, I highly doubt it would help you much since youd above all going to be limited to the transfer rate of the CF card and memory card reader. To my knowledge the fastest CF card transfer rate is at 45MB/s from the Sandisk Ducati series CF cards while the average SATA2 HDD is at 3GB/s. See the choke. Now for creating files and saving them on the computer itself, thats where youll see the benefit of a RAID setup. Keep in mind though RAID 0 is not the best for security. You are essentially banking on not just one HDD never failing, but two as your data is now spanned across two HDDs instead of one. Personally I use RAID 1 for increased read times and security. Check this wiki article for more info: LINK (external link)
ugly_a
Sep 26, 2008 07:06 |  #3
RAID0 is not worth the effort and the risks generated for the benefits it provides unless you need to stream one humongous chunk of continuous data from one place to another.
Gear-lust-free since yesterday.
milorad
Sep 26, 2008 08:28 |  #4
Striping is best for video-related applications.... and honestly only really worth it with a good heavily cached RAID controller and more than two drives.
Most motherboard RAIDs are not going to give you the kind of bang you're hoping for -- even if your CF card/reader could keep up (it can't)
Gear List (external link) - Yeah baby.
gjl711
Sep 26, 2008 08:43 |  #5
RAID 0 is nice and it will increase your HD bandwidth and it is quite noticeable if you work with large photoshop files. For example I am scanning all my old photographs. It is easier for me to scan multiple pictures at once and then break them up in PS. These files are huge some approaching 2 gig. I do notice the speed difference between my main PC and my backup PC as the backup does not have a RAID array.
However, running RAID 0 is risky. You are doubling the odds off catastrophic failure affecting your data. If either disk goes, your screwed and restoring stuff from your backups. So, if you really want to go RAID 0, I recommend going either RAID 0+1 or RAID 1+0. It takes more drives but give you the speed boost with the addition of redundancy. That way if a drive fails, you simply replace the drive and there is no data lost.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
adam8080
Sep 26, 2008 09:17 |  #6
I'm currently working some bugs out of my RAID 10 setup right now, but when I get done I'll run a couples tests for you if you want. Also I just had a hdd fail and I was able to keep on working. Nice.
Huntsville Real Estate Photography (external link)
ben_r_
Sep 26, 2008 09:48 |  #7
Yea RAID 0+1 or equiv would be the way to go, but then youre talking a min of 4 HDDs.
adam8080
Sep 26, 2008 09:53 |  #8
RAID 5 is almost worthless with today's hdd capacities, and raid 0 it risky with 2 drives and gets worse with more. If you need the speed at any cost though, RAID 0 is the way to go.
snails
"I used the last of it to tip the strippers."
Sep 26, 2008 15:05 |  #9
I had Raid 0 on my desktop, motherboard driven. When my motherboard pooped out and I could not replace it, my raid array was worthless. It had to be reformatted. I lost a lot of data that day.
Support the forums - donate here
adam8080
Sep 26, 2008 15:25 |  #10
Yes, it isn't for backup. It is either for speed or to continue running in case of a hdd failure.
jr_senator
Sep 27, 2008 18:48 |  #11
adam8080 wrote in post #6384758 (external link)
RAID 5 is almost worthless with today's hdd capacities...
I don't understand what HHD capacity has to do with it. If a disc fails what difference does the capacity make? My current desktop has RAID 0 as did my previous desktop. My next one will have RAID 5 and, I'm sure, larger discs than I now use.
adam8080
Sep 29, 2008 07:32 |  #12
jr_senator wrote in post #6393251 (external link)
http://blogs.zdnet.com​/storage/?p=162 (external link)
jr_senator
Sep 29, 2008 22:42 |  #13
Now I understand.
1,156 views & 0 likes for this thread, 8 members have posted to it.
2910 guests, 138 members online
