Thread started 25 Sep 2008 (Thursday) 22:44
A Tripod Built for Two
traviswalken
Sep 25, 2008 22:44 |  #1
I have done quite a bit of research and have narrowed my search to 2 tripods.
I am looking for a tripod for my wife (5' 4" ) and me (5' 10" ). I am planning to get an 005xprob or 190xprob with the 488rc2 head. Would the 005xprob be too tall for my wife to use easily? I understand that the height can be modified by leg angles and not fully extending legs. However, will this just be frustrating for her? Also important, she will be the primary user of the tripod.
Note: I asked this question on the popphoto forum but then remembered that there seemed to be A LOT of people on this forum who use the 005xprob and 4888rc2...are any of you shortish?
Thanks!
jeromego
Sep 25, 2008 23:13 |  #2
traviswalken wrote in post #6382655 (external link)
Thanks!
im 5'5 and i was actually thinking of getting the 055xprob but it was kinda tall for me so i settled for the 190xprob which is still a little bit tall but manageable. if im not mistaken i think theres a thread here somewhere comparing both. and the only reason the op of that thread went for the 055x is because he is about 6 ft tall. otherwise everything is the same for both including the horizontal adjustment of the center column.
as you can see on my sig that i have the exact set up youre thinking of getting.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
jeromego
Sep 25, 2008 23:15 as a reply to  @ jeromego's post |  #3
by the way, heres the thread with the review of the 055xprob...https://photography-on-the.net/forum/showthre​ad.php?t=529785
Jerome
Canon CPS Member
Wilt
Sep 25, 2008 23:51 |  #4
You do not have to extend all the leg sections fully, if you merely need a shorter tripod for your wife, and it would not be a frustrating exercise to do. Furthermore, you should consider the height without the center column raised, for max stability, so even with leg sections fully extended, 53" height with fully extended legs will scarcely be a problem for someone 63" tall. Get the 055 unless you are absolutely needing the lightest thing you can find for hiking.
Maxdave
Gallery: 49 photos
Sep 26, 2008 05:37 as a reply to  @ Wilt's post |  #5
I have a Giottos MT-7371 with MH-3300 head which, when all three sectons are fully extended, is about a foot too tall for me (I am 5'11"). I regularly use it with the lower leg sections not fully extended. As long as the extension required is marked (I used a simple pencil line drawn on the lava tube leg section), there is no problem setting it up.
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
milorad
Sep 26, 2008 05:51 |  #6
Thinking outside the box for a bit here... here's the criteria as I understand it.
1. tripod has to be tall enough for you
2. tripod has to suit the primary user (your wife) who is shorter than you
3. 1 and 2 should be achieved with the minimum of fuss, especially for your wife.
since shorter tripods don't get any taller, the challenge is to make a partly-extended tripod super-easy to use.
the answer is to buy one with a leveling centre column, or leveling base. Luckily manfrotto offer such a beast. When you extend the tripod legs quickly and without much regard for perfect balance, it's then a 10second job to get the base level for shooting panos or whatnot.
your wife will find it quite easy to deal with partially extended legs, and even you will get some added ease of use when shooting on uneven ground.
Gear List (external link) - Yeah baby.
traviswalken
Sep 26, 2008 10:54 |  #7
milorad wrote in post #6383767 (external link)
will the leveling bubble on the tripod head accomplish the same thing as the "leveling center column or leveling base" you described?
milorad
Sep 26, 2008 23:21 |  #8
often not, because the point of pivoting is very often BELOW the leveling bubble on a tripod head.
imagine that, the top is level, but the bottom that spins for panoramas is not... so you get that weird oscilating effect like when a spinning coin falls flat. The leveling bubbles on heads are usually only good for one perspective which just isn't good enough.
it doesn't make it possible to be imprecise with your leg extensions.
Either you get a leveling base, or you get a spinning platform for the top of your ball head... I prefer the leveling base.
Diesel_Dog
Sep 27, 2008 14:31 |  #9
I have the 55ProB and 488, and find it a bit short for some situations (I'm 6'1"). It seems quite tall when set up on the kitchen floor, however seems to shrink when I get it out in real world situations...
Dillon
5Dmk II | 30D | 17-40L |24-70L | 70-200L F4 IS | 300L F4 IS | 1.4 TC
1,196 views & 0 likes for this thread, 6 members have posted to it.
2904 guests, 138 members online
