Hi all, first time poster. (I think- I've been hanging around for a long time...)
Does anyone know if the 5Dmk2 can be (gasp) used to shoot video with (gasp again) another lens brand using a cheapo manual lens adapter?
thanks...
borealis Senior Member 257 posts Joined May 2005 Location: yukon More info | Sep 26, 2008 06:16 | #1 Hi all, first time poster. (I think- I've been hanging around for a long time...) "There is no point in having sharp images when you've fuzzy ideas." - Godard
Pandya Member 243 posts Joined Mar 2008 More info | Sep 26, 2008 07:01 | #2 Anything that can be adapted to EF mount should work. And that's a pretty long list.
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 26, 2008 07:07 | #3 Yes. Anything that it can take stills with it'll be able to take video with... which is a phenomenally long list once you start taking into account the M42 etc. adapters. Gear Listhttp://www.codastudios.com.au
Sep 26, 2008 07:13 | #4 Thanks!! "There is no point in having sharp images when you've fuzzy ideas." - Godard
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | If what I read is true, then the 5D MkII uses the same mirror box assembly as the original 5D. If that is definitely the case, then you still need to be careful which lenses you will be adapting since some of them will still cause interference issues (the mirror will hang up, the lens' aperture lever will rub against the mirror box, etc). You can correct these issues with a little simple filing or by shaving the mirror. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
Sep 29, 2008 07:42 | #6 Thanks argyle, good points to remember. "There is no point in having sharp images when you've fuzzy ideas." - Godard
| Latest registered member is johntmyers418 1745 guests, 177 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
