Thread started 26 Sep 2008 (Friday) 06:56
With regard to DOF and teleconverters...
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Sep 26, 2008 06:56 |  #1
I was sitting here trying to calculate whether you'd get a shallower DOF using a telephoto (100-300 f/4, for argument's sake) at 300mm f/4 or with a 1.4x making it 420mm f/5.6... when I realised I'd been going about it all wrong. It's an effective f/5.6 - the darkening there is not a function of aperture at all, thus should have no impact on DOF in itself. Thus the teleconverter is always going to result in narrower DOF.
So my thinking now is that to calculate the correct DOF for a 300mm f/4 lens with a 1.4x teleconverter on is to use 420mm f/4 as your figures?
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
xarqi
Sep 26, 2008 07:15 |  #2
Sort of, yes, and no.
It's not just the "effective" f ratio, it's the real f ratio. f has changed as a result of using the TC.
Use of a TC will always result in a narrower DoF.
Use 420 mm and f/5.6 as your figures. These are the optical parameters of the compound lens produced by adding a TC.
P.S.
Or so I see it. I'm always happy to be proven wrong ;)
John_B
Gallery: 178 photos
Sep 26, 2008 07:21 |  #3
Jim G,
That theory seems to work on Julian's Lens Calculator (external link) ;)
click to see (external link)
wimg
Sep 26, 2008 08:23 |  #4
Jim G wrote in post #6383969 (external link)
It still is a function of aperture. Aperture is defined as (front) lens diameter in mm divided by focal length in mm. Adding a 1.4X converter means you are multiplying the total focal length of the lens by 1.4X, and hence decreasing the maximum aperture by 1.4X, IOW, a decrease by 1 f-stop. This is also why it gets darker in your viewfinder.
No. You need to use 420 F/5.6 in this example. See above.
HTH, kind regards, Wim
1,068 views & 0 likes for this thread, 4 members have posted to it.
913 guests, 109 members online
