Thread started 11 Feb 2005 (Friday) 18:18
What flash bracket do you use
Tripod
Joined Jul 2004
Feb 11, 2005 18:18 |  #1
Looking to get a flash bracket to use with a EOS 1D MkII and 550EX. Anyone get a recomidation?
IanD
Honorary Moderator
Gallery: 35 photos
Joined Dec 2003
Feb 11, 2005 19:07 |  #2
Check out the Wimberley F-1. wicked rig.
Ian (®Feathers & Fur)
Have You Hugged Your Mallard Today?
More Images- (external link)My Gear
flickr
Belmondo
Joined Jul 2003
Feb 11, 2005 19:09 as a reply to  @ IanD's post |  #3
They call it F-1 because it costs about the same as a F-1 race car.
I'm not short. I'm concentrated awesome!
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 11, 2005 19:12 |  #4
usually, I use the shoe, bounce flash, and the Lumiquest 80/20 bounce thing. Its been a good combination so far. I do have a Manfrotto bracket of some sort that telescopes, angles, and other sorted things. If I can't bounce, I will use it to get the flash up higher away from the lens.
Tom
5D IV, M5, RP, & various lenses
ssim
Joined Apr 2003
Feb 11, 2005 20:14 as a reply to  @ Tom W's post |  #5
I recently got the Manfrotto 233B and then put a mini head ball on it. It is pretty cool.
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 11, 2005 20:34 |  #6
Sheldon, that's the one I have. Its very adjustable.
Tom
mikesd
Joined Mar 2004
Feb 11, 2005 20:38 |  #7
Another Manfrotto 233b here also.
50D, 10D, XT, S3 IS, Tamron 17-50, Tamron 28-75, Tamron 18-200, 18-55, 430EX II
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 11, 2005 20:40 |  #8
Yep - there it is:
IMAGE: http://www.pbase.com/photosbytom/image/38929902/medium.jpg
Tom
DaveG
Joined Aug 2003
Feb 12, 2005 06:05 as a reply to  @ Tom W's post |  #9
Tom W wrote:
Yep - there it is:
Can you get the flash over the lens - DIRECTLY over the lens - in both horizontal and vertical shooting positions?
If you can't. then that bracket is going to be useless. 99% of the reason that I use a bracket is to remove side shadow from behind the subject, and the only way that can be done is if the shadow falls behind the subject, and not to one side.
Flash side shadow is unaccepable in a professional image and I would expect to be screamed at in any newsroom in the country if I turned one in!
Perhaps that bracket does allow the flash to be positioned over the lens but I don't see that in the photograph.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 12, 2005 06:45 |  #10
Yes, Dave, you can. Its easy in horizontal, but a bit more annoying in vertical since its not a swing bracket.
It pivots at the bottom of the upright shaft so that you can align it right over the lens. At the top is a small ball head so that you can level your flash.
Personally, I prefer to mount the flash on the shoe and use the lumiquest for ordinary flash people shots, if there is no ceiling bounce available. The bracket has found more use for setting up awkward lighting angles for macro-type shooting.
Tom
IanD
Honorary Moderator
Gallery: 35 photos
Joined Dec 2003
Feb 12, 2005 08:17 as a reply to  @ Belmondo's post |  #11
True, it is expensive, but it is very adaptable to almost any situation. Bonus is that it comes apart and stows away in a side pocket of your camera bag. I'll set it up and take a picture of it.
flickr
Belmondo
Joined Jul 2003
Feb 12, 2005 09:37 as a reply to  @ IanD's post |  #12
Thank you, sir. I'd like to see it.
cactusclay
Joined Jan 2005
Feb 12, 2005 09:54 |  #13
I've heard some people complain about the stroboframe camera flip, but if the nuts are all adjusted right, it seems to do the trick for me and cost around seventy bucks. The flash is right over the lens in both positions.
ssim
Joined Apr 2003
Feb 12, 2005 11:40 as a reply to  @ cactusclay's post |  #14
Here is the Wimberley F-1 Tele Flash Bracket on the new tripod.
The way this bracket mounts is on the from of the lens plate. There is also and adaptor to mount the bracket on the camera body. Picture of that to follow.
IMAGE: http://www.pbase.com/ssim/image/39671135.jpg
IMAGE: http://www.pbase.com/ssim/image/39671136.jpg
HJMinard
Joined Jan 2004
Feb 12, 2005 15:48 as a reply to  @ ssim's post |  #15
I haven't used one, but these Really Right Stuff (external link) brackets look nice. Does anyone have any experience with these?
~ Jay ~
Canon EOS 20D ... lenses and stuff
Without the Way, there is no going; Without the Truth, there is no knowing; Without the Life, there is no living. <><
Help remove children from poverty: Compassion (external link)
18,069 views & 0 likes for this thread, 17 members have posted to it.
1764 guests, 154 members online
