https://photography-on-the.net/forum/showthread.php?t=577340
https://photography-on-the.net/forum/showthread.php?t=577338
Cross-referenced to avoid double posts!
plasticmotif Goldmember 3,174 posts Likes: 2 Joined Sep 2008 Location: Tennessee More info | Sep 29, 2008 12:02 | #1 https://photography-on-the.net/forum/showthread.php?t=577340 Mac P.
kbreit Senior Member 639 posts Joined May 2005 Location: Elgin, IL More info | Sep 29, 2008 13:07 | #2 Let me address the first ones. Interesting shots, especially the first. I'm seeing a bunch of purple fringing along her hair. Whether you knew it or not, you framed her eye between her hair and the grass. The colors are slightly washed out, but that's not a fundamental problem. I could see her toe at the bottom left of the photo which is slightly distracting if you look for it. Good shot though. I happen to like it. Canon 350D, Canon 18-55, Tokina 12-24, Sigma 70-200 f2.8 EX, 430EX
Sep 29, 2008 13:18 | #3 Thanks for the reply. I've only been really interested in this for maybe a month. I've been trying to soak up all the information I can. Mac P.
kbreit Senior Member 639 posts Joined May 2005 Location: Elgin, IL More info | Sep 29, 2008 14:16 | #4 I'm not actually recommending Lightroom. As I said, I use Bibble Pro and am very happy with it. I've never used Lightroom. I'm just pointing out lots of people use it (and frankly, it's probably a great app). Canon 350D, Canon 18-55, Tokina 12-24, Sigma 70-200 f2.8 EX, 430EX
nbaer89 Junior Member 26 posts Joined Sep 2008 More info | Sep 29, 2008 16:40 | #5 The first picture from the first group is good. But I think its missing a bright smile which portrays a lot of emotion in pictures. The second is okay for a snapshot but needs a lot of work on the exposures. The second set are decent but it appears you used a flash when it seems a bright enough day to do without it causing the rocks to white out and strange water reflections. Keep up the work though. Canon XTi 400D|Standard Kit Lens|Quantaray AF LD 70-300mm F4-5.6|
| Latest registered member was a spammer, and banned as such! 2686 guests, 145 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
