Could some of you tell me what lighting you use for occasional, outdoor portraits? Do I really need to invest in a ton of expensive flashes and umbrellas, or is there a better, more economical way for the casual shooter?
JamesP Goldmember More info | Sep 29, 2008 18:32 | #1 Could some of you tell me what lighting you use for occasional, outdoor portraits? Do I really need to invest in a ton of expensive flashes and umbrellas, or is there a better, more economical way for the casual shooter? 1Dx - 5DIII - 40D - Canon 24-70LII, 100L macro, 135L, 16-35L, 70-200 f4 and 100-400L lenses
2112 Senior Member 863 posts Joined Jan 2005 More info | Sep 29, 2008 18:41 | #2 Permanent banJames P wrote in post #6405587 Could some of you tell me what lighting you use for occasional, outdoor portraits? Do I really need to invest in a ton of expensive flashes and umbrellas, or is there a better, more economical way for the casual shooter? I shoot natural light with just my popup flash around sunset most the time outdoors and like my results. If its early enough in the day, i wont even use the flash. Depends on what look you are going for. Links may be NSFW. 40D,Tamron 28-75 f/2.8,Nifty Fifty,Vixia HV30 HD
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Sep 29, 2008 18:53 | #3 James P wrote in post #6405587 Could some of you tell me what lighting you use for occasional, outdoor portraits? Do I really need to invest in a ton of expensive flashes and umbrellas, or is there a better, more economical way for the casual shooter? Hi James, Robert
DigitalSpecialist Goldmember 2,286 posts Likes: 1 Joined May 2008 Location: Finding a New World, thru my camera More info | Sep 29, 2008 19:14 | #4 James, I prefer natural light whenever possible. But for general Portraits outside I use reflectors, and my flash with a hood, or reflector attached to it. A good quality reflector will cost less than 100US and last you for years. JIM
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 29, 2008 20:04 | #5 I'm not a fan of reflectors, by the time they're reflecting enough light to be useful they tend to blind people. I use off camera lighting held by an assistant, which probably doesn't fit into your "occasional" requirement. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
jcolman Goldmember More info | Sep 29, 2008 20:33 | #6 tim wrote in post #6406138 I'm not a fan of reflectors, by the time they're reflecting enough light to be useful they tend to blind people. I use off camera lighting held by an assistant, which probably doesn't fit into your "occasional" requirement. A white piece of foam core held a few feet away serves as a very nice source of fill light and won't blind anyone.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Foam core and reflectors work very nicely as long as you can get close enough to the subject. Unfortunately reflectors are not the most efficient devices. Robert
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 29, 2008 20:40 | #8 If you're trying to light a person to be about the same brightness as a sunny background then you need to reflect a lot of light onto them, that level of light does blind them. Flash is far more effective. If you just want fill sure use it, but fill flash is easier and doesn't require stands or people to help. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
hawk911 Cream of the Crop More info | Sep 29, 2008 21:07 | #9 tim wrote in post #6406138 I'm not a fan of reflectors, by the time they're reflecting enough light to be useful they tend to blind people. I use off camera lighting held by an assistant, which probably doesn't fit into your "occasional" requirement. a gold can certainly blind someone for a few seconds/minutes while you use it, but the white side should be just fine. They can be very effective, when used correctly. I've seen it done. HAWK Photography Gallery
Titus213 Cream of the Crop More info | Sep 29, 2008 21:50 | #10 A simple hot shoe mounted 430EX flash will work wonders outdoors. Dave
| Latest registered member is semonsters 1590 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
