Haha, I guess if you do a dive specifically to take a gear picture, you should at least pull the labels ehhh?
My dive companion and I were only around 90 feet or so in this area. I'm not easily narked, so I usually just dive air, then deco on 50-100% depending on the plan. Mixes are terribly expensive if you don't do it yourself, and since I don't yet blend anything, try to save a few bucks when I can. I would rather spend 14 bucks on one-two deco fills, and get multiple dives, than the high priced fills for mixes.
My next goal however is Trimix and full cave. I was hoping to get started this Spring, however a few unexpected finances from diving set me back. I love photography, and would love to have a decent housing for my topside gear. It's sad that with all that I have, not one part of it can be used underwater - yet! B&H would get about 4500.00 bucks for the setup I would like. But then again, video is appealing too. Can't even imagine that cost. Lol.
Thanks for the compliments on the dive trailer. That in itself has become almost a hobby. It's turned into a money pit seems like, but then again, I guess as you work on something and spend on it constantly, that it would appear to cost more than it does. I would like to add a cascade system, however I just don't have the proper axle allowances to go that far with the cargo weight I have in there now. Mostly I built the trailer to be dived out of, rather than from around. Meaning, most folks arrive to their dive destinations and have to unload all their gear, I found it easier to set up and assemble my gear from inside the trailer and use it as both a changing room, protection from the weather, and to of course proved security. It's really worth is weight in gold on trips where you can just lock things up and carry what you need to the hotel room - not to mention when you return home late at night and just plug up the shore line to power the blower and hit the sack.
