Can anyone recommend a descent/cheap 72mm anti glare UV filter? I had purchased a cheap $20 Tiffan on Amazon, but can't stand the green lens flare. Anything better from $20 - $35?
sokun Senior Member 276 posts Joined Sep 2008 Location: Los Angeles, Ca More info | Oct 01, 2008 15:40 | #1 Can anyone recommend a descent/cheap 72mm anti glare UV filter? I had purchased a cheap $20 Tiffan on Amazon, but can't stand the green lens flare. Anything better from $20 - $35?
milorad Senior Member 515 posts Joined Sep 2008 Location: Melbourne, AU More info | Oct 01, 2008 15:44 | #2 anti-glare? you may actually want a Circular Polarizer to reduce glare from water, windows, etc. Gear List
Probably have my jargon mixed up. I use my UV filters indoor to protect my glass, but have noticed that when taking pictures with a light behind my subject, there's this nasty green lens flare that the filter creates.
homersapien Senior Member 350 posts Joined May 2008 Location: Denver, CO More info | Oct 01, 2008 16:40 | #4 So don't use a UV filter; they don't do anything, and can only HURT image quality. Even a circular polarizer will introduce flare in some situations.
So even the high end UV filters will have the same lens flare? I'll probably just shoot with my lens hood on 100% of the time.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 01, 2008 19:24 | #6 No, good multicoated UV filters won't flare any more in normal use than your unprotected lens will. And a lens hood won't help if the light source is in the picture, filter or no filter. But good multicoated filters (B+W MRC, Hoya S-HMC, Heliopan SH-PMC) aren't in the $20-$35 price range for any filter size EF lenses take. Jon
Woolburr Rest in peace old friend. 66,487 posts Gallery: 115 photos Best ofs: 2 Likes: 143 Joined Sep 2005 Location: The Tupperware capitol of eastern Oregon...Leicester, NC! More info | Oct 01, 2008 21:27 | #7 sokun wrote in post #6418569 So even the high end UV filters will have the same lens flare? I'll probably just shoot with my lens hood on 100% of the time. Now you are talking...lens hoods should be on all the time...with the exception of those times when you are using creative filters. Real hard to rotate a CPL with the lens hood on. Some lenses are very prone to flare when you add a filter....the 28-135 is notorious for horrible flare when you throw a filter on it. People that know me call me Dan
Oct 02, 2008 02:48 | #8 sokun wrote in post #6418569 So even the high end UV filters will have the same lens flare? I'll probably just shoot with my lens hood on 100% of the time. Yes, even the most expensive filter will increase flare to some extent. Of course, the more you spend the less flare you'll get. Frank Hollis - Retired mass spectroscopist
| Latest registered member was a spammer, and banned as such! 2938 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
