Thread started 03 Oct 2008 (Friday) 08:06
Should I use a diffuser at all?
James ­ P
Oct 03, 2008 08:06 |  #1
OK, I confess. I let a camera salesman talk me into buying a Gary Fong Lightsphere. I've used it when I wanted a fill flash for outdoor portraits and have been generally pleased with the results. Since joining this forum, I've read the anit-Fong comments and now I'm wondering what the more experienced among you use instead. Any diffuser at all? Do you just dial back the flash? I don't always have something to bounce off of. I would appreciate your guidance.
1Dx - 5DIII - 40D - Canon 24-70LII, 100L macro, 135L, 16-35L, 70-200 f4 and 100-400L lenses
- "Very good" is the enemy of "great." Sometimes we confuse the two.
bieber
Oct 03, 2008 08:08 |  #2
If you don't have anything to bounce off of, the lightsphere doesn't give you light any better than straight-on flash, and wastes a ton of battery power to boot. Outdoors, I generally use an off-camera strobe in an umbrella, or sometimes just bare, depending on the situation. If you need on-camera fill, just use the flash bare.
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 03, 2008 09:00 |  #3
Yes.
Plan ahead? Carry something & have someone hold it if your subject needs it. The results are worth it.
Angeline outdoors
Wilt
Oct 03, 2008 09:32 |  #4
A camera salesman selling Lightspheres? I thought you had to go to a web site as the means of being relieved of your money?! Ditch the Fong any time there are no nearby ceiling and walls to bounce light back to the subject, you are wasting light and battery power for no reason, if it is mounted in those circumstances.
'Soft light' is from 'large apparent source size', which is why umbrellas and softboxes provide soft light...they are large in comparison with the tiny flash lens. So using anything to serve as a larger surface apparent source is what you want to do, for softer light.
James ­ P
Oct 04, 2008 06:32 |  #5
Thanks for your help. It is much appreciated.
SkipD
Joined Dec 2002
Oct 04, 2008 06:55 |  #6
James P wrote in post #6429451 (external link)
None of the 'tupperware' diffusers (Fong's overpriced stuff, Stofen, etc.) are worth carrying in my camera case.
I use a LumiQuest Promax System (external link) kit instead. It is far more versatile than any of the 'tupperware', in that it is truly functional indoors or out (using the various configurations it is capable of), and it packs into a flat "wallet" that takes very little space in my camera case.
Skip Douglas
SuzyView
Oct 04, 2008 07:13 |  #7
The Lightspheres are interesting things. I use it indoors for close-up portraits, and that's it. Outdoors, it doesn't work. For a small room with low ceilings, I actually think the Lightsphere does interesting things too. But it's usually good.
James ­ P
Oct 04, 2008 18:00 |  #8
Let this be a warning to anyone who is being sold a bill of goods by a smooth talking salesman. I tried the Lightsphere and what the others in this forum say is true. Don't buy this over priced gimmick. It dosen't work as advertised. Take the time to learn how to use your flash settings, search the web for flash techniques, or ask someone here. You'll be a better photographer and $ 44 richer.
tim
Light Bringer
Oct 04, 2008 18:00 |  #9
I use off camera flash, usually bounced into an umbrella, but sometimes direct if I need the power. If it's just fill I use direct undiffused flash.
1,536 views & 0 likes for this thread, 7 members have posted to it.
1590 guests, 139 members online
