I'm thinking of buying a 16 gig SDHC card for my soon to arrive XSi. Will it format correctly in the XSi?
Thanks!
Jim
JimHoltz Senior Member 452 posts Joined Apr 2008 Location: Des Moines, Iowa More info | Oct 03, 2008 19:37 | #1 I'm thinking of buying a 16 gig SDHC card for my soon to arrive XSi. Will it format correctly in the XSi?
leadweight Senior Member 252 posts Joined Aug 2008 More info | Oct 03, 2008 20:29 | #2 I use an 8 gig card without problems. That holds about 500 raw images. Do you need 1000 at once?
an_DREW-STi- Member 33 posts Joined Jul 2008 Location: San Diego,CA More info | I'm currently using a 16gb Delkin card and have 0 problems whatsoever.
iseecanonpeople Senior Member 255 posts Joined Sep 2008 Location: behind a viewfinder More info | Oct 04, 2008 01:05 | #4 i suggest you get 2x8gb instead of just 1 atleast you have backup unless you have 2x16gb
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Oct 04, 2008 01:27 | #5 iseecanonpeople wrote in post #6434651 i suggest you get 2x8gb instead of just 1 atleast you have backup unless you have 2x16gb Not really needed unless you use the camera for critical applications, where you'd likely have an X0D or above and a few 4gb cards for the speed anyway. 16gb cards are fine, just get them from a reputable source. Real Sandisk Extreme III cards currently top the charts in speed (well, at least in the affordable price range) and are likely to outlast you camera. I've had a total of 10 sandisk cards, a 1gb ultra II, 2x 2 gb ultra II, 12gb extreme III, 8gb extreme III sdhc, 3x 2gb ultra II sd 2008 edition, 2x 2gb ultra II sd, and none of thse cards ever had any problems (other than the fact i lost the 1gb ultra II). Even on extended trips i'll just take my 12gb card, so much easier, and no problems even after about 30k shots on that card (which holds only about 800 shots at a time, so i've definately emptied it a few times. I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
Thanks everyone. That's what I wanted to know.
iseecanonpeople Senior Member 255 posts Joined Sep 2008 Location: behind a viewfinder More info | Oct 04, 2008 09:38 | #7 basroil wrote in post #6434746 Not really needed unless you use the camera for critical applications, where you'd likely have an X0D or above and a few 4gb cards for the speed anyway. 16gb cards are fine, just get them from a reputable source. Real Sandisk Extreme III cards currently top the charts in speed (well, at least in the affordable price range) and are likely to outlast you camera. I've had a total of 10 sandisk cards, a 1gb ultra II, 2x 2 gb ultra II, 12gb extreme III, 8gb extreme III sdhc, 3x 2gb ultra II sd 2008 edition, 2x 2gb ultra II sd, and none of thse cards ever had any problems (other than the fact i lost the 1gb ultra II). Even on extended trips i'll just take my 12gb card, so much easier, and no problems even after about 30k shots on that card (which holds only about 800 shots at a time, so i've definately emptied it a few times. cool i just hope he doesnt loose them even on non-critical situation...i still say 2 x 8gb,or whatever I dont think at that size you wont even fill it up... I stay on the safe side of things.. that's why flash drives, external drives and NAS are widely available and recommended even at home, back-up is really something you should look at.. and even if you fill up the 16 or 8 imagine the tedious task of browsing through them 1k+ and 3-450+ raw images respectively...
billrhea Member 172 posts Joined Jan 2008 More info | Yes I would never just have one card with that many pictures on it. It's always better to have more card. When I shoot I use many cards swapping them out every 100 pics or so. Canon 5d Mark II
| Latest registered member is MWCarlsson 926 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
