FORUMS Photo Sharing & Visual Enjoyment Transportation
Thread started 04 Oct 2008 (Saturday) 10:47
Amberley Airshow October 2008 - Saturday
AMD72
Oct 04, 2008 10:47 |  #1
Sharing some shots from Saturday's airshow at Amberley, Queensland, Australia.
The F111 dump and burn featured during the show as it is sadly the last airshow for this party trick
F111 nearly landing then throttling up and starting the fuel dump
1.
http://farm4.static.fl​ickr.com …11547843_aedb30​715a_o.jpg (external link)
and a fraction of a second later as she gained some height
2.
http://farm4.static.fl​ickr.com …12395740_9abc2f​6930_o.jpg (external link)
some other dump and burn passes ...
3.
http://farm4.static.fl​ickr.com …12396446_8d8d2d​e363_o.jpg (external link)
4.
http://farm4.static.fl​ickr.com …12396694_dedb1c​3d90_o.jpg (external link)
A wave to the crowd and a wave goodbye back.
5.
http://farm4.static.fl​ickr.com …11548825_3fd2ee​fb80_o.jpg (external link)
6.
http://farm4.static.fl​ickr.com …12397862_8c2a65​1192_o.jpg (external link)
Some other aircraft included....
Vampire...
http://farm4.static.fl​ickr.com …12404640_505dc9​e22c_o.jpg (external link)
C130 Herc....
8.
http://farm4.static.fl​ickr.com …12398460_c8870e​949e_o.jpg (external link)
more pics follow...
Andrew
Clicky 4 Flickr Piccies (external link)
AMD72
Oct 04, 2008 10:53 |  #2
Some F18 Hornets...
9.
http://farm4.static.fl​ickr.com …12398804_65953b​1096_o.jpg (external link)
10.
http://farm4.static.fl​ickr.com …12404420_2c5f73​2d95_o.jpg (external link)
11.
http://farm4.static.fl​ickr.com …12403530_d4bbb9​fecd_o.jpg (external link)
PC3 Orion...
12.
http://farm4.static.fl​ickr.com …12403822_ed9e11​ee5f_o.jpg (external link)
Another of the F111 with the wick turned up
13.
http://farm4.static.fl​ickr.com …11550691_8ddca2​969e_o.jpg (external link)
And finally some static displays...
Connie tail...
14.
http://farm4.static.fl​ickr.com …12399470_86218b​8113_o.jpg (external link)
C17 Globemaster...
15.
http://farm4.static.fl​ickr.com …12399948_2c609b​41d2_o.jpg (external link)
16.
http://farm4.static.fl​ickr.com …12400400_66c7ab​ed62_o.jpg (external link)
T28 Trojan...
17.
http://farm4.static.fl​ickr.com …11553459_7b8377​b117_o.jpg (external link)
F15 - business end
18.
http://farm4.static.fl​ickr.com …12401018_eeb823​7c0b_o.jpg (external link)
Seahawk...
19.
http://farm4.static.fl​ickr.com …12402158_66c111​0b5a_o.jpg (external link)
and finally Squirrel...
20.
http://farm4.static.fl​ickr.com …12402894_17cbc5​e4e1_o.jpg (external link)
Andrew
Medic1
Joined Dec 2004
Oct 04, 2008 11:24 |  #3
Very nice shots! Thanks for posting
Jamie ­ Holladay
Joined Nov 2005
Oct 04, 2008 13:50 |  #4
Andrew you have a nice set of images. However, I had to change them to links because the images are larger than 1024 on the longest side. Also the OP is only allowed to embed up to 8 images. Please see the Link to the Image Posting Rules in my Signature.
PhotosGuy
Joined Feb 2004
Oct 04, 2008 15:45 |  #5
3Turner
Rick Rolled Fanboy
Oct 04, 2008 17:46 |  #6
Nice variety you posted of the airshow. Those wide angle statics make some of the aircraft look distorted.
Robert [¯Ô¯] | Gear | Gallery (external link)
Scout7id
Oct 04, 2008 19:06 |  #7
Awesome set!
-- Don Fuller --
I am a veteran. At seventeen I wrote a blank check payable to the "United States of America" for an amount up to and including my life.
AMD72
Oct 04, 2008 19:08 |  #8
Medic1 wrote in post #6436286 (external link)
Thanks Medic
Jamie Holladay wrote in post #6436899 (external link)
Cheers - apologies for that. If I get time, would it be possible to resize 8 of the shots and repost them in this thread?
3Turner wrote in post #6437928 (external link)
Thanks, there was a greater variety of aircraft, including many aerobatic planes that I did not manage to capture. I know the wide angles (taken with a 10-22) loose the true perspective of the subject, but taking those photos was more about capturing different views rather than recording correct details.
Andrew
Jamie ­ Holladay
Joined Nov 2005
Oct 04, 2008 19:09 |  #9
AMD72 wrote in post #6438360 (external link)
Sure. After you resize just replace the [IMG] tags in your first post.
Desertraptor
Gallery: 212 photos
Oct 04, 2008 19:22 |  #10
Damn fine shots
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
DAdeGroot
Oct 05, 2008 05:52 |  #11
Some great shots there Andrew. I'm still going through the ones I got today.
Dave
http://www.degrootphot​ography.com.au/ (external link)
http://www.digitalphot​ographycourses.com.au/ (external link)
Quae narravi, nullo modo negabo!
asysin2leads
I'm kissing arse
Oct 05, 2008 20:36 as a reply to  @ DAdeGroot's post |  #12
Nice clear shots for 1/50th. Were those handheld or monopod? Great images. Thanks for sharing.
Kevin
https://www.google.com ….com&ctz=Americ​a/New_York (external link)
AMD72
Oct 05, 2008 20:51 |  #13
Desertraptor wrote in post #6438436 (external link)
Damn fine shots
DAdeGroot wrote in post #6440348 (external link)
asysin2leads wrote in post #6443824 (external link)
Thanks Peter, Dave and Kevin.
The shots were all handheld. I was using a 70-200 f/4 IS for the flying / taxiing shots. Initially I had the IS on mode 2, but because of the angle of the flight path to our close viewing location I wasn't always moving it directly sideways and I think the IS for the vertical might have interferred with some of the earlier shots and I ended up turining it off. Rather than holding the lens at the zoom ring I tried holding it at the hood and this made it a lot steadier. Naturally there were plenty of OOF and blurred shots that have since been vapourised :) The static shots were taken with a 10-22mm.
Andrew
2,274 views & 0 likes for this thread
Latest registered member is Mickclem
793 guests, 304 members online
