Thread started 06 Oct 2008 (Monday) 15:03
Flash photography in tungsten environment...
rightaway
Joined Nov 2005
Oct 06, 2008 15:03 |  #1
Hi,
I have to do flash photography in places where the predominent lights are tungsten. The subject colors are ok but the background ends being yellowish.
How can I get uniform color balance for both the subject and the background? Can I use a filter on the flash and use a "tungsten" color balance on the camera? any other tricks?
thanks
Wilt
Oct 06, 2008 15:10 |  #2
Put a 1/2 CTO gel on the flash, shoot with WB Tungsten.
S-S
frustrating simple something
Oct 06, 2008 15:12 |  #3
basically if you colour-match the flash to the ambient light you can use a single white balance setting for the whole room. if you cant get hold of proper gels or coloured diffusers try orange cellophane & stick a couple of layers over the flash head, and test it beforehand so you know how much to use
NathanJK
Oct 06, 2008 15:25 |  #4
You need to use a CTO (color temperature orange) gel on the flash and set the camera for a tungsten color balance.
Here's a nice big sheet of CTO gel, you can make like 20 of them for small flashes, or even cut one out thats the right size for a monolight AND a bunch of flashes: http://www.bhphotovide​o.com …_Full.html#spec​ifications (external link)
Here's something that you might find helpful, its a pack of filters. Not only can you find CTO in there, but it will have plus green (for balancing for flourescent) and other useful ones! http://www.bhphotovide​o.com …rrection_Kit.ht​ml#reviews (external link)
I personally carry around 3 filters per flash: CTO, straw (I think it's 1/2), and plus green. I then keep one of the big lee swatchbooks in the case too in case I need a red or something like that.
http://www.shuttersnap​studios.com (external link)
http://shuttersnapstud​ios.wordpress.com (external link)
Riff ­ Raff
Oct 06, 2008 16:12 |  #5
If you're non-crafty (and/or lazy) like me, you can get the pre-fab velcro and gel kit:
http://www.adorama.com​/FAHSS.html (external link)
http://www.adorama.com​/FAHGK.html (external link)
I'm generally using the 3/4 CTO gel on my flashes, with white balance set to 3200K. This seems to match the tungsten bulb used in spotlights pretty well.
Shawn McHorse - Shawn.McHorse.com (external link) / AustinRocky.org (external link)
DSLR: 5D Mark III Compact: S100 Flash: 580EX II Bag: Tamrac Rally 5
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS,
50mm f/1.4, 85mm f/1.8
tim
Light Bringer
Oct 06, 2008 18:15 |  #6
I attach gels with velcro - cut out the gel, glue velcro to it, and I already have it on my flashes.
rightaway
Joined Nov 2005
Oct 06, 2008 19:13 |  #7
Thanks!!
I'll check it out!!
NathanJK
Oct 08, 2008 02:43 |  #8
I do what Tim does as well, piece of velcro on either end, and one on either side of the flash head. I have a piece of really thin sanded really smooth plywood that I attached velcro to either side of also, I just stack all of the gels I'm not using on that.
Shooting
Oct 08, 2008 21:23 |  #9
When bouncing I have to do a FEC.if using a gel should I have to do more of a FEC to compensate for additional light loss??
2,089 views & 0 likes for this thread, 7 members have posted to it.
1229 guests, 181 members online
