Thread started 08 Oct 2008 (Wednesday) 17:56
Will a infrared filter on my camera pick up the infered on a tv remote?
Extinctionjet
Oct 08, 2008 17:56 |  #1
eos 400D
surely it should pick somehing up?
"Though I Fly Through The Valley Of Death, I Shall Fear No Evil. For I Am At 80,000 Feet And Climbing."
Gear: Canon 5D MkIII .. Canon A1.
Canon 100mm f/2.8, Canon 24-105mm f/1.5,
Extinctionjet
Oct 08, 2008 17:56 |  #2
on B shutter.
SkedAddled
Gallery: 16 photos
Oct 08, 2008 19:09 |  #3
That's a decent test for determining if the camera will be suitable for infrared photography.
It helps if the camera has live view, as in being to view the shot the camera would take in the LCD display. That way, you can see the IR remote beam going on & off. Failing that, just take a picture with the remote aimed at the camera while pressing a button on the remote.
*EDIT* this is done with the IR filter mounted to the lens.
Craig
Of course I'm all right! Why? What have you heard?!?
Please have a look at an offshoot to this forum. Created by members, open to members, and all others. (external link)
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Oct 09, 2008 03:09 |  #4
your 400D has a built in filter that is designed to stop Infrared light getting to the sensor and let all visable light pass thru. A IR filter fitted externally is designed to reduce as much as possible the visable light getting thru & permit infrared inhindered. The combination of the two results in really long exposure times - suspect to see a TV remote you'd need to be using at least 30 seconds with as big an apeture as you can get.
What are you needing to achieve?
TF posting: here :-)
John_B
Gallery: 178 photos
Oct 09, 2008 07:40 |  #5
Extinctionjet,
If the TV remote uses IR light (which most do), then like others said a long exposure with wide open aperture is needed to see the IR light from the remote.
click to see (external link)
Extinctionjet
Oct 09, 2008 11:08 |  #6
its very dim but ill try with a higher apature and let you know. :)
904 views & 0 likes for this thread, 4 members have posted to it.
2836 guests, 138 members online
