Thread started 11 Oct 2008 (Saturday) 13:39
gitzo 2541 and RRS BH-40 ballhead question (main lock knob woobly)
lukx
Oct 11, 2008 13:39 |  #1
Ok I just got my first tripod and ballhead :) I screw BH-40 onto 2541 plate but even screwing it tight it still sometimes got loose. Are there any tricks to tighten it properly or I'm doing something wrong? Also is the main lock knob on bh-40 supposed to be a bit wobbly? I mean I notice you can pull it (there is spring or something) and then you can change it;s position in y axis for better orientation when tightened. BUt even when tightened you can feel a that it's a bit loose. Is it normal?
www.lukx.com (external link) :: cgi
jhom
Oct 11, 2008 14:09 |  #2
I believe there is a set screw on the 2541 base plate that you can use to prevent the ballhead from loosening. Also, if you cannot hand tighten the ballhead use a strap wrench to give you a little more torque.
Jim
2,823 views & 0 likes for this thread, 2 members have posted to it.
2901 guests, 131 members online
