I own a 77mm wide-angle Lee adaptor. It's definitely necessary with the 10-22, but I'm not really sure if it is necessary at 17mm with a 1.6x sensor.
Looking at my adaptor, the way it's machined looks difficult to do, which is probably the reason for the $30 price increase. It's hard to describe, but the threads on the adaptor ring are "in-cut" so the filter holder (when attached) will be very close to your lens...which prevents vignetting. Hard to explain here, but easier to see when you look at the adaptor in person.
Even though the wide-angle adaptor is expensive, everyone told me it was the way to go. Except for the price, there's no drawback to using the wide-angle adaptor. And if you think about it...you are more apt to use a wide-angle lens when using filters (think landscape photography) so the wide-angle adaptor is the way to go.
Hope this helps,
Bryan
