Thread started 11 Oct 2008 (Saturday) 21:28
How do you straighten the picture?
dcsmith40D
Oct 11, 2008 21:28 |  #1
I feel like there is a way to straighten a photo that was taken out of level. I am using the Digital Photo Professional because I can't figure out how to use the Elements 6.
Canon 40D; 50 f1.8, 70-200 f2.8 IS L, 580 EX II, 1.4 TC, 24-70 f2.8 L, (2) 430 EX II
David
gjl711
Oct 11, 2008 21:34 |  #2
I don't think DPP has a straighten tool. I think all you can do is rotate 90 degrees.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
MaTeR ­ MaN
Oct 12, 2008 07:21 as a reply to  @ gjl711's post |  #3
Elements should have a ruler tool. If so, use it to trace a horizontal or vertical line to adjust the photo with and then go to edit/image > rotate canvas > arbitrary. PS should have the default angle already selected. Minor cropping will be required.
Canon 5D - Canon 450D
17-40L _ 50 1.8 II _ 28-135 IS _ 70-200L
B+W _ Giotto
Zazoh
Oct 12, 2008 08:15 |  #4
Picasa3 has a great straighten tool and is free. DPP doesn't unfortunately.
A Camera - A Lens -- Gear Doesn't Matter
dcsmith40D
Oct 12, 2008 09:09 |  #5
I appreciate the responses. I was able to figure out how to use the Elements program enough to open and straighten a couple of photos. I find the DPP easier to navigate so I haven't put enough effort into learning Elements.
David
Peano
Oct 12, 2008 10:22 |  #6
You can straighten images with the crop tool. Here's a tutorial:
http://graphicssoft.ab​out.com …nts/ss/straight​encrop.htm (external link)
Peano
RadiantPics.com (external link)
dcsmith40D
Oct 12, 2008 13:57 |  #7
Thanks for the tutorial. That is very good. Is there more tutorials for Elements?
David
cdifoto
Don't get pissy with me
Oct 12, 2008 13:59 |  #8
Usually I grab one end while my lumberjack friend grabs the other end. Then we twist.
OK more seriously, I do it in Lightroom if ultimate straightness is critical. It's not possible in DPP. Shame on Canon for that.
2,527 views & 0 likes for this thread, 6 members have posted to it.
952 guests, 183 members online
