Thread started 12 Oct 2008 (Sunday) 15:41
Goin' nutz with the ERR99 code with my Rebel XT
PhotoFireMan
Oct 12, 2008 15:41 |  #1
:evil: Just recently, started getting the ERR99 code on my 2 year old Rebel XT. I've tried removing the battery, cleaning the contacts, etc. But yesterday on a trip to the zoo, it started up again. I was using a Tamron 75-300mm lens (which I have had nothing but good shots with since I bought it over a year ago). After about 5 shots, BAM!! There it goes. I tried turning off the battery, removing the lens and reattatching it, but it kept on acting up. ONLY when I turned my camera to the sports icon, did it seem to help. That only made me more confused. I would try to change the mode, but would get the code again after a few shots.
I am at my wits end. I suppose I could send it off and see if my repair shop can figure it out.
Any help you can offer would be great!!
Doug Brown
Blytheville, Arkansas
http://www.geocities.c​om/cheap_shots_by_doug (external link)
http://community.websh​ots.com/user/dougbrown​ark (external link)
http://photos.yahoo.co​m/dougfirefighter93 (external link)
PhotoFireMan
Oct 12, 2008 15:51 |  #2
Actually, my photos are now at:
http://www.flickr.com/​people/dougbrownphotog​raphy/ (external link)
Doug Brown
Tsmith
Formerly known as Bluedog_XT
Oct 12, 2008 15:51 |  #3
Doug before you have it checked out you might wanna take out the small lithium battery also. Let it sit for several minutes before reinserting.
JackProton
Oct 12, 2008 17:46 |  #4
Does the camera work OK with other lenses? Your 75-300 lens may be the issue - perhaps a sticky aperture diaphragm. I had a similar problem with a Tokina 24-200mm. Try using the lens in Av mode with the aperture wide open and see if the errors stop. If you only get errors when the lens is stopped down, this could be the problem. Another test is to use the DOF Preview button and check whether the aperture closes down completely and smoothly every time. If it works OK wide open then you'll need to have the lens serviced.
929 views & 0 likes for this thread, 3 members have posted to it.
2460 guests, 124 members online
