Anyone ever have any trouble connecting the Quantum power pack and a Canon 580 EX ?... Can't seem to get the flash to power on when its connected... just wondered if there were any tricks to this? Any help is much appreciated. Thanks.
StephenHutchinson Member 87 posts Joined Mar 2005 Location: Toronto, Canada More info | Oct 12, 2008 20:34 | #1 Anyone ever have any trouble connecting the Quantum power pack and a Canon 580 EX ?... Can't seem to get the flash to power on when its connected... just wondered if there were any tricks to this? Any help is much appreciated. Thanks. Canon EOS 5D Mark III | Canon EOS 7D | Canon EOS 70D
gromeo Senior Member 981 posts Likes: 1 Joined Feb 2007 Location: Orlando, FL More info | Oct 12, 2008 22:55 | #2 Do have the correct cable and do you have batteries installed in the flash Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
Oct 12, 2008 23:00 | #3 The cable is correct... and I'm not sure if there are batteries in the flash itself, this is a friend of mine who is using my 580 EX... she's asleep now so I can't ask her directly..but would having batteries in the flash be a bad thing? Canon EOS 5D Mark III | Canon EOS 7D | Canon EOS 70D
Titus213 Cream of the Crop More info | Oct 12, 2008 23:06 | #4 From what I've read you need batteries in the flash. Dave
gromeo Senior Member 981 posts Likes: 1 Joined Feb 2007 Location: Orlando, FL More info | Oct 12, 2008 23:07 | #5 The first time I connected my turbo 2x2 I forgot to put the batteries back into the flash, the 580 needs to have the bats installed in order for the turbo to work. Here is the steps to make sure the turbo is powering the flash. Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
Oct 12, 2008 23:12 | #6 Awesome.. thank you both so much.. I'll let my friend know in the morning that she should follow these steps... thanks a million! Canon EOS 5D Mark III | Canon EOS 7D | Canon EOS 70D
jureis Member 47 posts Joined Sep 2007 Location: Montreal Canada More info | Oct 13, 2008 13:13 | #7 ive also heard from some pros that if you keep all 4 batteries in the flash it could overheat and burn out. that being said they recommend you use a plastic battery because without 4 batteries in the unit it wont work. Bodies: 50D Gripped, 20D Gripped, A-1
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Oct 13, 2008 15:43 | #8 jureis wrote in post #6488263 ive also heard from some pros that if you keep all 4 batteries in the flash it could overheat and burn out. that being said they recommend you use a plastic battery because without 4 batteries in the unit it wont work. Now, that's a load of crap! The purpose of the dummy battery is to decrease the total voltage of the internal batteries so that they are not used to charge the main flash capacitor. But the voltage is still high enough to run the electronics of the flash. They serve that function on the 550EX because there is no way to set the 550EX to either use or not use the internal batteries for charging the main capacitor. ...Leo
jureis Member 47 posts Joined Sep 2007 Location: Montreal Canada More info | alright just passing along what ive heard Bodies: 50D Gripped, 20D Gripped, A-1
BlackeyCole Senior Member 480 posts Likes: 21 Joined Feb 2007 Location: Alamogordo New Mexico More info | Oct 13, 2008 15:52 | #10 If you are using the Turbo battery it only supplies power to the strobe element you still need batteries in the flash ot a QB1 connected powering the electronics so it will work. What you are supplying power to is the light element only and you are using the Quantum to do two things 1 speed up time between charges and save the in flash batteries to power the electronics long so you can get more flashes out them since they are not charging the strobe capacitor Click Here and Join the POTN flickr Group Today!
silvex Cream of the Crop More info | Oct 13, 2008 16:07 | #11 You also need to let the flash know to use the external power source. You can choose: Internal, external or both. I have set mine to use both, but I use canon's powerpack. Not to hijack the tread, but. How does the turbopack compares to canon's powerpack / .
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Oct 13, 2008 20:28 | #12 silvex wrote in post #6489185 You also need to let the flash know to use the external power source. You can choose: Internal, external or both. I have set mine to use both, but I use canon's powerpack. Not to hijack the tread, but. How does the turbopack compares to canon's powerpack / Other than the fact that the Turbo 2x2 (don't know about the other Turbo models, though) will outlast the batteries in the Canon battery pack, their performance in terms of recycling speed are the same. Weight-wise, the Turbo 2x2 is much heavier than the Canon battery pack, and bigger, too. ...Leo
GentlemanVillain Goldmember 1,116 posts Joined May 2008 More info | Oct 13, 2008 20:40 | #13 Permanent banStephenJames wrote in post #6484968 The cable is correct... and I'm not sure if there are batteries in the flash itself, this is a friend of mine who is using my 580 EX... she's asleep now so I can't ask her directly..but would having batteries in the flash be a bad thing? Yep...it needs batteries in the flash itself.
silvex Cream of the Crop More info | Oct 13, 2008 20:55 | #14 PacAce wrote in post #6490550 Other than the fact that the Turbo 2x2 (don't know about the other Turbo models, though) will outlast the batteries in the Canon battery pack, their performance in terms of recycling speed are the same. Weight-wise, the Turbo 2x2 is much heavier than the Canon battery pack, and bigger, too. I just read their "ratings" and it is about ~700 full powerflashes. I get around that with four duracells 2650 NiMH in the 580EXII. I have yet try to see how many I get when the Canon power pack (CP-E4) with eight 2650. I took at least 250+ with it just recently, but I would really like to take a test. The batteries were almost fully charged after taken the 250+ shots. .
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Oct 13, 2008 21:47 | #15 silvex wrote in post #6490694 I just read their "ratings" and it is about ~700 full powerflashes. I get around that with four duracells 2650 NiMH in the 580EXII. I have yet try to see how many I get when the Canon power pack (CP-E4) with eight 2650. I took at least 250+ with it just recently, but I would really like to take a test. The batteries were almost fully charged after taken the 250+ shots. And all these were all full power flash shots using the 2650 NiMH batteries? ...Leo
| Latest registered member is MWCarlsson 1493 guests, 125 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
