Thread started 17 Feb 2005 (Thursday) 18:56
a75 blurry corners or dirty lens?
link26
Joined Jan 2005
Feb 17, 2005 18:56 |  #1
the top corners of my pictures tend to be blurry. they are especially noticeable if taking pictures with text.
I once foolishly applied 50% rubbing alcohol to the lens, but i quickly cleaned it off.
so i'm not sure if it's the camera, or if I didn't clean off the lens completely.
does anyone else's a75 have blurry corners?
Don ­ Schaeffer
Joined Nov 2003
Feb 17, 2005 22:58 |  #2
I haven't seen any such problem with my A70.
--Don
xdjoynerx
Joined Jul 2004
Feb 18, 2005 00:03 |  #3
thats just a p&s lens for you. they are not as sharp at the corners as they are at the center.
you need to post up samples, and the f/stop used.
ekrunaj
Joined Feb 2004
Feb 18, 2005 11:00 |  #4
Just to be sure that your attempt to clean the lens with 50% alchohol is not a problem, you should invest in a small "lens pen" and follow the directions for its use. Never use volatile fluids for cleaning of coated lenses.
Zekevarg
Feb 21, 2005 12:50 as a reply to  @ xdjoynerx's post |  #5
How will the f/stop settings affect the corner blurryness?
When I process my pictures in photoshop I notice the distorted
corners when i crank up the contrast or color saturation.
Cheers, Zeke
S45_fornow...
Joined Dec 2003
Feb 21, 2005 13:17 as a reply to  @ Zekevarg's post |  #6
Cheers, Zeke
Every lens/camera combination has a "sweet spot" where a certain f-stop will give sharper images than other f-stops. This can change with focal length (full-wide or tele).
1,788 views & 0 likes for this thread, 6 members have posted to it.
1219 guests, 126 members online
