I made a 14" beauty dish for my off-camera flash out of a terra cotta bowl, a CD spindle case, some gutter parts from Home Depot, spray paint, and a convex blind spot mirror. So far, I only took a few test shots so far but it seems to work well.
The inspiration came from this blog post:
http://davidtejada.blogspot.com …auty-dish-for-sb-800.html![]()
The dish is pretty much the same; my main change was having a holder for my flash and not putting the weight on the flash head.
This is how it looks from the side. The flash is in the back and the flash holder which is constructed out of several gutter parts has a window so that I can change the output and turn it on or off. The thing hanging at the bottom is the wireless remote trigger.
Here is the dish. You can see the CD case. On the inside is a convex mirror that receives the light from the flash and then spreads it into the dish.
Similar view when the flash is firing.
The beauty dish does not give you a nice clean shaven look in the middle of the night.
