Thread started 14 Oct 2008 (Tuesday) 23:21
C&C Please BW Conversion
sunnygirl
Oct 14, 2008 23:21 |  #1
Welcome C&C as I seem to struggle with BW conversion
Here is original
1.
Susan
5D MKII - Accumulating way too much gear - bring on retirement so I have time to use it.......
sunnygirl
Oct 14, 2008 23:22 |  #2
My 1st attempt - seems a bit flat to me.
Susan
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Oct 15, 2008 00:24 |  #3
i'm not sure how this will look on your monitor... last time i tried a black and white on this uncalibrated monitor, it turned out too dark on others.
this isn't a pure black and white... i applied a warming filter at 25%. first thing's first, i masked the man's shirt and flowers to bring back some detail, then merged the layers, adjusted contrast, sharpness, and added noise.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
sunnygirl
Oct 15, 2008 00:40 |  #4
Thanks, Reign, unfortunately it looks really dark on my calibrated monitor, however I think I can see what you are trying to achieve. I was way wrong and I ran it through Noise Ninja, instead of adding noise.
Susan
Nathan
Gallery: 18 photos
Oct 15, 2008 00:46 |  #5
i really need to buy spyder2... sorry about that
sunnygirl
Oct 15, 2008 02:40 |  #6
Sorry tamtanium yours is even darker on my monitor. Are you PP the original or my darker BW, maybe thats why they are coming up dark
Susan
chauncey
Oct 15, 2008 04:52 as a reply to  @ sunnygirl's post |  #7
If you have problems with your base image, blown highlights, your conversion won't improve things.
Anticipation of a conversion starts when you squeeze the shutter.
fadetoblack22
Oct 15, 2008 06:08 |  #8
Reign wrote in post #6498278 (external link)
I don't think this looks better than the OP's version. Kind of looks like a bad flash shot on my monitor.
Nathan
Gallery: 18 photos
Oct 15, 2008 12:08 |  #9
This was my second attempt at a black and white version. I guess I'm not sure of what it is really that I want to achieve.
fadetoblack22
Oct 15, 2008 12:50 as a reply to  @ Nathan's post |  #10
I added a few touch-ups to show how I think it should look:
Method:
1) Hold down alt and click the new layer button in the layers area.
2) Select overlay and tick the 50% gray box.
3) Now select a nice soft brush and lower the opacity to between 20 and 30%
4) Press "D" to set the palette to B&W. Paint on the image as if you are dodging and burning.
5) If you make a mistake switch to the opposite colour.
dkord
Oct 15, 2008 12:56 |  #11
image deleted
The devil is in the details...Especially at 100% crop!
https://www.flickr.com​/photos/eosdawg/ (external link)
fadetoblack22
Oct 15, 2008 13:29 |  #12
dkord wrote in post #6500953 (external link)
Here's the tweaks I made in CS3, took about 15 minutes.
yeh, that looks good! although I think their skin looks too dark.
sunnygirl
Oct 15, 2008 15:28 |  #13
fadetoblack22 wrote in post #6499151 (external link)
My histogram stated at capture that there were no blown highlights, however the grooms shirt was very shiny. I personally think I could have turned down flash compensation a bit more.
I will try a few different conversions using the tips given here and see what I get.
Thanks everyone, your C& C is appreciated.
Susan
Nathan
Gallery: 18 photos
Oct 15, 2008 22:22 |  #14
The groom's shirt in the original picture isn't bad at all... I just thought it better to tone it down a little in a b&w because it stands out a little too much, in my opinion... I was careful to note, however, that the flowers details seem lost in the original post... look at mine and you should see more detail.
I looked at the my edit on a calibrated monitor and I'm not too concerned about how dark it is. I would lighten it up a notch, but I like the high contrast and grainy look.
Otherwise, I think the image does suffer a little from direct flash (if that's where all the shiny spots on the face, flowers, almost blown shirt cuff, etc... comes from)
dkord
Oct 16, 2008 01:57 |  #15
Yeah, the faces can be lighten, but I would check the histogram again, it was definately climbing up the right wall on these jpegs. Could be the background highlights too.
Soft bounce would of help control the harsh lights.
Glad you've moved on, I'll delete my conversion.
1,459 views & 0 likes for this thread, 6 members have posted to it.
2776 guests, 137 members online
