While I am only using a 18-55 mm kit lens, I'm still pleased with the results. It definitely is a lot different than my S1 IS, that is for sure. Both shots were done with manual focus since that will be good practice for me. It's a lot harder than I thought it would be because I was also taking them hand held as well. Found it was easier to just set the camera, and then slowly move my body forward or backwards until it came into focus. Both were also done with natural light. The flash was just a little bit much. I cropped them both as well, since I don't have a true macro lens yet. Thanks for all of your inspirations!
By the way, this was the biggest hoverfly I've ever seen! It easily was close to an inch in length.
