Hi,
I have a 300d and I'm thinking about getting an ef 100-400 lens for the sports photography that I love. Will this lens give good results with this base unit or is there a better option.
CURNIL Hatchling 1 post Joined Oct 2008 Location: New Zealand More info | Oct 15, 2008 21:28 | #1 Hi,
sol95 Senior Member 661 posts Joined Jul 2008 Location: Sydney, Australia More info | Oct 16, 2008 00:28 | #2 i'm not exactly sure what you mean...if you are asking if your 300D will push the boundaries of what the 100-400L can cope with, i highly doubt it. Bodies: 5D mk III
twofruitz Senior Member 840 posts Joined Oct 2007 Location: AUSTRALIA More info | Oct 16, 2008 00:44 | #3 Did the 300d just get released in NZ
jsinon Goldmember More info | Oct 16, 2008 05:48 | #4 The only issue you might have is that this lens is a light hog. If you don't have very good to great light you are likely going to have to crank up the iso to get the shutter speed you need to stop action. At least that is my experience with this lens, which I use as my main wildlife lens. For a faster 400mm lens you will need to roughly triple your budget though. I love this lens for it's versatility and wouldn't give it up. I guess the only limiting factor would be your 300d's high iso performance. Fuji X-T2, Fuji X-Pro1, XF18-55, XF10-24, XF50-140
luant16 Senior Member 424 posts Likes: 1 Joined Jun 2006 More info | Oct 16, 2008 09:37 | #5 i used 70-200 2.8 IS with 300D before, the camera was capable to take static object & focus point is not a problem with aperture 2.8 however as for moving object the performance of the camera isnt very good even when u use AI servo with hacked. However you might still able to take few shoots with it.
vpnd Goldmember 1,483 posts Joined Oct 2007 Location: nd More info | Oct 16, 2008 09:52 | #6 they will work together well if you have enough light. I have a rebel xt that I pull out for nastalgia sake once and a while and I am leary of shooting over iso400. you will run into problems with light. Canon "Snappy".... Thanks Mom and Dad!
edrader "I am not the final word" More info | while the 100-400L isn't the best sports lens the 300d is the weak link here. getting even a 20d will offer major improvement. http://instagram.com/edraderphotography/
| Latest registered member was a spammer, and banned as such! 2831 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
