How can the composition and lighting of this picture be improved?
Thanks!
melindac Member 31 posts Joined Aug 2008 More info | Oct 16, 2008 22:01 | #1 How can the composition and lighting of this picture be improved?
ejay79 Member 135 posts Joined May 2007 Location: Illinois, USA More info | Oct 16, 2008 23:34 | #2 First, I would step back and give them more room to "walk" in the frame. Then maybe get even lower to the ground if the background isn't too cluttered looking. ejiphotos.com
Pen6uiN Senior Member 502 posts Joined Jan 2008 Location: Melbourne, Australia More info | Oct 17, 2008 00:18 | #3 crop it so u can't tell the horizontal plane is a bit off Canon 5D mkII (Gripped) | 16-35 2.8L II | 24-70 2.8L | 70-200 2.8L IS | 50mm 1.2L | 580EX II | TC 2x | Manfrotto 055XPROB with 804RC2 / 496RC2 | PocketWizard FlexTT5
fadetoblack22 Senior Member 320 posts Joined Aug 2008 More info | The main things I can see in the photo are the non-straight horizon in the bg and the fact that the geese are out of focus. This may be due to shooting with a too slow shutter speed.
WalczakPhoto Goldmember 1,034 posts Joined Apr 2008 More info | Oct 17, 2008 11:05 | #5 Well...from a compositional stand point, geese are hard to shoot because for most people they are very common place. Generally the best shots of geese and ducks are those where there is some "action"...taking off or landing on water, etc.. In the case of these guys though, they do have some interesting facial features, so I would have tried to get some close ups. Not to jack your thread, but here's an example...
These guys have really interesting faces, so that's a good place to put compositional emphasis. Just be warned...they can be mean little buggers! This little turd bit me right after I took this shot! LOL!!! Now as far as the lighting goes...a good rule of thumb is to keep the sun behind you and over your shoulder. In this shot, the sun looks to have been in about the 10 o'clock position relative to the camera....I would have moved around so that the sun was more in the 5 o'clock or 7 o'clock position. Back lighting works good when you're trying to do a silhouette, but I don't think that's what you were trying to do with these shots. Alrighty, hope this helps! Jim "It is horrifying that we have to fight our own government to save the environment. " - Ansel Adams
Oct 18, 2008 00:23 | #6 ejay79 wrote in post #6510254 First, I would step back and give them more room to "walk" in the frame. Then maybe get even lower to the ground if the background isn't too cluttered looking. As far as lighting, I think that could work once the composition is changed a little bit. Finally, while it isn't lighting or composition - the focus seems to be off on this shot which is distracting. Thanks! You are right. How can I improve the focus of this shot. I was using spot metering and focusing on the bird. Should I have used a better metering?
Oct 18, 2008 00:23 | #7 Pen6uiN wrote in post #6510438 crop it so u can't tell the horizontal plane is a bit off Good catch! I did not notice that! Thanks!
Oct 18, 2008 00:24 | #8 Walczak Photo wrote in post #6512544 Well...from a compositional stand point, geese are hard to shoot because for most people they are very common place. Generally the best shots of geese and ducks are those where there is some "action"...taking off or landing on water, etc.. In the case of these guys though, they do have some interesting facial features, so I would have tried to get some close ups. Not to jack your thread, but here's an example...
These guys have really interesting faces, so that's a good place to put compositional emphasis. Just be warned...they can be mean little buggers! This little turd bit me right after I took this shot! LOL!!! Now as far as the lighting goes...a good rule of thumb is to keep the sun behind you and over your shoulder. In this shot, the sun looks to have been in about the 10 o'clock position relative to the camera....I would have moved around so that the sun was more in the 5 o'clock or 7 o'clock position. Back lighting works good when you're trying to do a silhouette, but I don't think that's what you were trying to do with these shots. Alrighty, hope this helps! Jim Thanks Jim! You always have great advice. That is a much more interesting picture. What lens did you use?
marcus769 Senior Member 642 posts Joined Oct 2007 Location: Minnesota More info | Oct 18, 2008 00:57 | #9 Get them in focus and back up a little! 7D, 40D, 28-135mm IS, 50mm 1.8 II, 100mm 2.8L, 70-200mm 2.8L IS, 580 ex II
Oct 18, 2008 11:53 | #10 marcus769 wrote in post #6516207 Get them in focus and back up a little! ah you are right! i don't know what i was thinking. Metering is for lighting!
WalczakPhoto Goldmember 1,034 posts Joined Apr 2008 More info | Oct 20, 2008 09:59 | #11 melindac wrote in post #6516127 Thanks Jim! You always have great advice. That is a much more interesting picture. What lens did you use?
| Latest registered member was a spammer, and banned as such! 2693 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
