Hi,
I recently bought the Lee filter system starter kit, plus the CPL ring adapter which attaches to the front of the filter system, plus a B&W 105mm CPL filter. I have not had chance to try this out yet; hopefully will get the opportunity this weekend.
What I would like to know is if I can use the CPL attached to the filter system successfully without using any other filters, i.e. there will be a gap between the CPL and the front of the lens which will be the width of two Lee filters. Is stray light likely to get into the camera through the gap and upset things?
Thanks in advance,
Dave.
He has the same setup as you and he could definitely give you a concrete answer with the 105 mm CPL adapter. What body and lens setup are you going to be using this setup on?
