Thread started 18 Oct 2008 (Saturday) 20:28
ND Filter: 4x, 8x, or even GND?
funk1196
Oct 18, 2008 20:28 |  #1
Hey i'm always upset with shots where the exposure of the sky is too far of a difference from the foreground.
Like sunset/late day shots.
From what i understand, a ND filter is what i need... and that it brings the contrast down, so that i can fit both exposures into one (sky AND foreground)... is that correct?
So which one is the standard ND filter? 8x? 4x? If you could only get one, which one?
And for sunsets, would you recommend a GND? Anyone have any examples, cause i see this as a huge limitation not to be able to decide where the fading ends and begins with a GND. Maybe i want the sky to only be the top 3rd of the frame....=fail?
5D II, 16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100mm f/2.8 macro.
T1i, 10-22mm, 17-55mm.
580EX II, 430EX II, ST-E2, EF 2X II
SMP_Homer
Gallery: 29 photos
Oct 18, 2008 20:44 |  #2
for that scenario, you would need a gradient filter... only 1/2 the filter is darkened... a ND filter, the whole thing is darker
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
funk1196
Oct 18, 2008 22:30 |  #3
SMP_Homer wrote in post #6519853 (external link)
with a GND filter, dont you get really odd results?
lets say i have a sunset, with a tree in the foreground that takes up the whole right side of the frame from top to bottom.
and i use a GND to balance the sky from the foreground.
won't my tree be dark at the top, and light at the bottom? (the sky and ground properly balanced, but the tree unbalanced)
Piet
Oct 19, 2008 01:18 |  #4
funk1196 wrote in post #6520409 (external link)
Of course it's always an "in between"... There's no physical filter with the exact mask for large objects on the, let's say, "wrong side" of the picture / GND filter.
Under these circumstances i would take two pictures, one with the correct exposure for the sky and one for the foreground and merge them in post processing.
Regards,
Piet
765 views & 0 likes for this thread, 3 members have posted to it.
2949 guests, 129 members online
