This is pretty much straight out of the camera. Any comment and critique would be great.
Thanks.
mehran.mo Senior Member 998 posts Likes: 9 Joined Oct 2008 Location: Montreal, Canada More info | Oct 18, 2008 22:59 | #1 This is pretty much straight out of the camera. Any comment and critique would be great. Digital SLR: Canon 5D w/grip * EF 100mm f2.8 Macro USM * EF 200mm f2.8L MK I * 580EX II
luigis Goldmember 1,399 posts Likes: 3 Joined Jun 2008 Location: Buenos Aires, Argentina More info | Oct 18, 2008 23:12 | #2 Adjust the White balance,use foliage as the reference for white, around 2000K, remove the quite notable lens flare and it will improve a lot! www.luisargerich.com
SwingBopper Goldmember 2,664 posts Likes: 3 Joined Oct 2007 Location: Japan More info | Oct 19, 2008 00:59 | #3 Wowie zowie I like it. Could I use it in my next "I met ___ in a dream" composition? EOS 5D II, 40D, Sony R1, Olympus 1030, Canon S5-IS.
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Oct 19, 2008 06:46 | #4 Are you using a minolta? Hard to tell if that's a lens flare or the infamous spot created when shooting IR with some minolta models. Website
mehran.mo THREAD STARTER Senior Member 998 posts Likes: 9 Joined Oct 2008 Location: Montreal, Canada More info | Oct 19, 2008 07:42 | #5 That's not a minolta I can assure you, It's a hot spot created due to the reflection between lens and IRfilter(the one on the sensor keeping it from sensing IR). some lenses do this, like the the crappy 18-55mm lens I used. Digital SLR: Canon 5D w/grip * EF 100mm f2.8 Macro USM * EF 200mm f2.8L MK I * 580EX II
| Latest registered member was a spammer, and banned as such! 2780 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
