Thread started 19 Oct 2008 (Sunday) 14:53
Need help finding the right PS effect
justin-branam
Oct 19, 2008 14:53 |  #1
Hey everyone,
im doing some mock "Rosie the Riveter" pictures, and am having a hard time coming up with the right effect for the girls. I want them to have that cartoon look like the original poster. im using PS3 so if anyone can suggest a good filter effect i would appreciate it. feel free to mess with the photo below. it is one of the girls next to the original poster. thanks.
http://www.justinunder​water.com/ (external link)
5Dmk2, 15mm EX DG f/2.8, 17-40 f/4L, 50mm f/1.8, 60mm f/2.8, 100mm f/2.8, Tamron 28-75 2.8, 70-200L f/2.8 IS, Canon 1.4x Tele and a 580EX
PamR
Oct 19, 2008 17:53 |  #2
Something like this?
IMAGE: http://upload.pbase.com/image/104778484/original.jpg
Pam
http://www.pbase.com/p​am_r (external link)
FlyingPhotog
Cream of the "Prop"
Oct 19, 2008 17:56 |  #3
justin-branam wrote in post #6523601 (external link)
Hey everyone,
You might consider going to your User CP and turning on "Image Editing OK" so that folks know you want visual help...
Jay
justin-branam
Oct 19, 2008 19:36 |  #4
PamR wrote in post #6524513 (external link)
WOW! Mind letting me know your process? this was just a fun gig im doing so im not use to this type of editing!
FlyingPhotog wrote in post #6524527 (external link)
normally i dont want people to edit my photos, but thats why i was sure to say "feel free to mess with the photo below" in my first post.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 19, 2008 23:08 |  #5
More: What is this technique called?
PamR
Oct 20, 2008 01:57 as a reply to  @ PhotosGuy's post |  #6
"We Can Do It" poster technique...
Here ya go, Justin. Let me know if it works for you...
This seems a lot more complicated than it really is. Starting with the original image:
IMAGE: http://upload.pbase.com/image/104801877/original.jpg
IMAGE LINK: http://upload.pbase.co​m/image/104801877/orig​inal.jpg  (external link)
Here's the layers palette setup so you can follow along:
IMAGE: http://upload.pbase.com/image/104801878/original.jpg
IMAGE LINK: http://upload.pbase.co​m/image/104801878/orig​inal.jpg  (external link)
1 - Dupe the background layer twice. You should now have 3 copies of your image. Name the middle layer "Dupe". Name the top layer "Blur".
2 - Activate the top layer ("Blur"), then turn it into a Smart Object by going to Filter>Convert for Smart Filters. This will allow you to fine tune filter settings. If you don't have PS CS3, ignore this conversion step. No problem, you'll just have to undo/redo the filter settings to taste. It's really just a convenience that saves a bit of time.
Now invert this top "Blur" layer (Ctrl+i) and set the blend mode to "Color Dodge". Desaturate by hitting Crtl+shift+U or Edit>Image>Adjustments>Desaturate.
4 - Now, go to Filter>Blur>Gaussian blur and play with the radius setting until you get something like this:
IMAGE: http://upload.pbase.com/pam_r/image/104801879.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480187​9.jpg  (external link)
5 - Merge this result to a new layer by opening a new layer on top, then hitting Ctrl+shift+alt+E. This is called "stamp visible". It merges a copy of all adjustments make up to this point on a new layer at the top of the stack. Another way to do this is to hold down the Alt key, then choose Layer>Merge visible. Name this layer "Merged":
6 - Dupe the "Merged" layer and name it "Lines". We're going to repeat the same invert/gblur move we did earlier but this time we're going for a different effect.
Invert the "Lines" layer (Ctrl+i), convert to a smart object if you want (Filter>Convert for Smart Filters). Set the blend mode to "Color Dodge". Choose Filter>Blur>Gaussian blur and adjust the radius to get outlines, something like this:
IMAGE: http://upload.pbase.com/pam_r/image/104801880.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​0.jpg  (external link)
7 - Repeat step 5 to Stamp visible (Ctrl+shift+alt+E). Desaturate this layer (Ctrl+shft+U, or Image>Adjustments>Desaturate):
IMAGE: http://upload.pbase.com/pam_r/image/104801881.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​1.jpg  (external link)
Run Filter>Stylize>Diffuse and choose "Anisotropic". Click OK. Depending on the resolution of your image, you'll have thick lines (low res) or thin lines (high res). This is where a bit of experience and experimentation comes into play.
If you have thin lines and want them thicker, dupe this layer and set the blend mode to "Mulitply". Repeat as necessary.
If you have thick lines and want them thinner, you can run levels and move the highlight slider to the left to thin them out. Play with the shadows slider to darken. Experiment until you like the result. Merge your result into one layer and name it "Lines-Anisotropic":
IMAGE: http://upload.pbase.com/pam_r/image/104801882.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​2.jpg  (external link)
8 - Now turn off the "Lines-stamp visible" and the "Lines-Anisotropic" layers. It should now look something like this:
IMAGE: http://upload.pbase.com/pam_r/image/104801883.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​3.jpg  (external link)
A little dirty around the edges, but your result may be a little cleaner if you used thinner lines.
9 - Open a new layer on top and name it "Clean up". Using the clone stamp tool, clean up the edges around the figure (make sure "Sample" is set to "Current and below"). You should now have a result close to this:
IMAGE: http://upload.pbase.com/pam_r/image/104801884.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​4.jpg  (external link)
It seems I have too many images, so I'll continue below...
Pam
PamR
Oct 20, 2008 02:00 as a reply to  @ PamR's post |  #7
------ continued from above ------
10 - Now place a copy of the original image on top of the stack. Here's one quick method:
Activate the background layer (the original image). Hit Crtl+J to add a duped version above the background layer. Now hold down Ctrl+shift and tap the right bracket key]. This will quickly add a copy of the background to the top of the stack. Name it "Shirt" and Set the blend mode to "Multiply".
Select All (or Ctrl+A), then Ctrl+T to bring up the free Transform tool and transform the poster shirt to cover up most of the new shirt. It doesn't need to be perfect.
11 - Add an inverted (hide all) mask to this layer. The shortcut is to hold down the Alt key while clicking on the "Add layer mask" icon at the bottom of the layers palette. Or, just add a layer mask, activate it by clicking on it, the hit Ctrl+i to invert it.
Now take a white brush and paint over the shirt area to expose the poster shirt and replace the new shirt. If needed, open a new layer and use the clone stamp/healing brush to blend in and fill.
IMAGE: http://upload.pbase.com/pam_r/image/104801885.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​5.jpg  (external link)
From this point, it just fine tuning. Adjusting the colors, darkening the top banner, coloring her skin, etc. To adjust colors, try Selective Color, Color Balance, curves...whatever you're most comfortable with. The same for her skin...you can also paint and experiment with blend modes.
Here's the final result:
IMAGE: http://upload.pbase.com/pam_r/image/104801886.jpg
IMAGE LINK: http://upload.pbase.co​m/pam_r/image/10480188​6.jpg  (external link)
Pam
1,081 views & 0 likes for this thread, 4 members have posted to it.
1371 guests, 177 members online
