Thread started 19 Oct 2008 (Sunday) 15:05
Eye problems
sarahbn
Joined Oct 2004
Oct 19, 2008 15:05 |  #1
IMAGE: http://img.photobucket.com/albums/v426/sarahbn/September%20-October%202008/Mt%20Gretna/IMG_0600_edited-1.jpg
Anke
Oct 19, 2008 15:08 |  #2
Not sure I understand the title of this thread. Can you explain?
Also the shot is out of focus. Unless that's the point of the title?
Anke
sarahbn
Joined Oct 2004
Oct 19, 2008 15:47 as a reply to  @ Anke's post |  #3
His eyes are glowing I can't get natural looking eyes
shannyD
"...in too much trouble"
Oct 19, 2008 15:48 |  #4
if you have photoshop or something like it.. you can clone that part out.
sarahbn
Joined Oct 2004
Oct 19, 2008 15:53 as a reply to  @ shannyD's post |  #5
I have elements but I always have trouble with the eyes They never look natural.
Pete
Oct 19, 2008 15:58 |  #6
Are you using a flash? That could be the problem, especially at dawn or dusk.
Pete
UK SE Catch of the Day
Wazza
Oct 19, 2008 16:09 |  #7
You did use the flash, 400mm, and 1/250th.. Looks a bit soft, maybe increase the ISO to 800 to double the shutter speed
New Zealand Photography Tours (external link) | Williams Photography - Queenstown Wedding Photography (external link) |
Instagram (external link) | Facebook - Weddings (external link) | Facebook - Landscapes + Tours (external link)
sarahbn
Joined Oct 2004
Oct 19, 2008 17:33 as a reply to  @ Wazza's post |  #8
Thanks I will try that next time.
shannyD
Oct 19, 2008 17:40 |  #9
IMAGE: http://i28.photobucket.com/albums/c239/daisydeadpeddles/a-1.jpg
TimothyScott
Oct 22, 2008 23:20 |  #10
in PS you could select the eyes one at a time and unsaturate them, seems natural most times.
sarahbn
Joined Oct 2004
Oct 26, 2008 19:44 as a reply to  @ TimothyScott's post |  #11
That looks better thank you. You used the clone tool?
M50D
Oct 26, 2008 20:22 |  #12
Sharah, at first I thought the subject wasn't focused on, but after looking closer the foreground and background are even blurrier than the subject which leads me too the conclusion it is probably either camera shake or a bad film on your glass. I see the focal length was 400mm, are you using the 100-400L IS lens? I use that one a lot myself. I have gotten some pretty sharp photos with 1/30 or slower shutter speed, so that alone is not the problem. If you can steady the camera with a tripod or monopod that will help, and try to focus (no pun intended) on holding the camera really still, perhaps using one of the focus points in the viewfinder as a sight to hold steady on a certain point of the subject. Did you do any post processing, such as sharpening and contrast levels? Did you crop this image?
I know you were asking about eyes and maybe you think I am going on a tangent here, but a sharper image will help to preserve the fine detail on the eyes as well as the whole image. Also, lighting quality and angle is everything when it comes to eyes as unfavorable lighting will take the lifelike look out of eyes virtually before anything else.
In fact here is a post where there was discussion on the very subject: https://photography-on-the.net/forum/showthre​ad.php?t=590968
fubarhouse
Oct 27, 2008 20:32 |  #13
Why does it always seem that in-camera flash produces red eye, but not external or mounted flashed? I'm sure there's a good reason.
Canon 40D, 580EXII, BG-E2N, RS-80N3 (Remote), Velbon Vel-flo 5 PH 248 (Tripod), Velbon RUP-43 (Monopod), Hoya CP Filters
Canon EF 50mm F/1.4 USM Canon EFS 17-85/4.0-5.6 IS USM, Canon EF 28-300mm F/3.5-5.6 L IS USM, Canon EF 100-400mm F/4.5-5.6 L IS USM.
My Gear | My Website (external link)
Laramie
Still livin' the cowboylife
Oct 29, 2008 13:56 |  #14
fubarhouse wrote in post #6573233 (external link)
Because the in-camera flash is closer to the lens, why mounted are usually higher flashing as a slightly greater downward angle? Just a thought...
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
2,523 views & 0 likes for this thread, 9 members have posted to it.
Eye problems
1504 guests, 130 members online
