Thread started 20 Oct 2008 (Monday) 00:04
Canon 40 D RAW Processing in DPP
maxloxton
Oct 20, 2008 00:04 |  #1
Guys,
I have just got back from my tour and I shot RAW from 40D. I need to know how should I convert them in DPP. I mean, should i convert in 8 Bit TIFF or 16 Bit TIFF; I have been converting the images from 5D and 20D in 8 bit previously.
|1D Mk IV| |5D Mk II| |1D Mk III| 17-40 f4L | 24-105 F4 L | 70-200L F4 IS| | Canon 70-200 2.8 | 300F4 L | 150 F2.8 Macro | 100 f2.0 |100 f2.8 MACRO | 15 2.8 Fisheye | 85 f1.2 L | 135 L f2.0 | 50 f2.5 Macro | 400 5.6 | 400 2.8 L IS | 1.4 X I | 1.4 X II | 2 X II | Mnafrotto 055 X Pro B |
| Flickr (external link) | Facebook (external link) |
tzalman
Fatal attraction.
Oct 20, 2008 02:19 |  #2
It depends on what you want to do after the conversion and on the software you have available. If you want to do extensive editing - shifting of tonal values to lighter or darker, adjusting contrast, changing colors or their saturation - and if your editor supports 16 bit, convert to the high bit depth. If you will only do things that don't involve large tonal shifts - sharpening, noise reduction, cropping, cloning, etc. - 8 bit will be enough, because you will probably end up in 8 bit anyway, either when you save the image as a jpg for archiving or posting or when you print it. If, OTOH, your editor doesn't support 16 bit, do as much as you can in the RAW converter since it will be calculated to 14 bit accuracy.
Elie / אלי
695 views & 0 likes for this thread, 2 members have posted to it.
1113 guests, 164 members online
