Thread started 20 Oct 2008 (Monday) 07:44
Re free sensor cleaning in Canada
The ­ Ghost ­ of ­ FM
Oct 20, 2008 07:44 |  #1
I know there is a free service provided by Canon Canada to clean the sensor in my camera. I was curious to know if this was a "while you wait" type of service or do they make you leave the camera with them for 2 weeks..or something like that?
Follow up question; Is the head office in Mississauga, Ont. the only location where this is performed or would stores like Henry's Camera provide the same free service?
Cheers!
GEAR LIST l WEBSITE (external link)
Qwest905
Oct 20, 2008 07:48 |  #2
it's only the head office in mississauga and i would call in before hand to make an appointment so you don't have to go back there.
Canon g10
str8six
Oct 20, 2008 08:41 |  #3
Take it to where you bought it. They should be able to clean it and do it for free right in front of you, assuming you bought it at a dealer and not mail order that is.
Regards, Len B
jrntr6
Oct 20, 2008 08:42 |  #4
I'm not sure if you actually can call and make an appointment. I seem to remember that they offer a 48 hour turn around for cleanings. But then again I haven't been there in 2 years.
Jeff
-50D, 30D & 300D 11-200MM of third party F2.8 glass, the bigmos and one little guy that some people call nifty
jrntr6
Oct 20, 2008 08:46 |  #5
str8six wrote in post #6527642 (external link)
Wow shops in calgary must be generous. In Ontario if you bought from a brick anr morter store chances are very high that it's either a big box store or henry's. The big electronic stores are no use for cleanings and henry's actually tells you to go to canon.
Jeff
dustyporch
Oct 20, 2008 08:59 |  #6
The guy at Henry's helped my out.... I bought an Arctic Butterfly kit from them, and they did the first cleaning for me.
My photos on Flickr... (external link)
Jack_C
Joined Dec 2003
Oct 20, 2008 12:07 |  #7
Canon Calgary will usually clean it within 24hrs, last time they were not as eager to help as they were before, guess they were busy. They also send all lenses to Ontario for repair now.
picturecrazy
soft-hearted weenie-boy
Oct 20, 2008 12:53 |  #8
Jack_C wrote in post #6528715 (external link)
They seem to send everything to ontario now. I always drop off my gear in calgary but it always gets shipped back to me from ontario. bodies, lenses, whatever. And they usually come back NOT repaired. :rolleyes:
Never tried getting the sensor cleaned for free so can't comment on that.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Oct 20, 2008 13:16 as a reply to  @ picturecrazy's post |  #9
So the consensus seems to be that Canon Canada will not do the cleaning while you wait and none of their authorized dealers will perform this action either unless you're buying a cleaning kit from them, which seems counter to the ideal of free cleanings, as is indicated in my owner's manual. :oops:
These "Arctic Butterfly cleaning kits, how expensive are they? Do they work? Can something be fashioned home-made style that will accomplish the same thing or is their brush/cleaning chemicals unique?
Thanks for your responses!
Cheers!
Quad
Joined Nov 2005
Oct 20, 2008 13:23 |  #10
Artic Butterflys are about $100 in Canada. They are a very soft thinish brush in a spinning handle to give a charge to attract the dust to the brush and I suppose it flings the old dust off.
You could also check out sensor klear, a lenspen for your sensor, they are about 10 US and 20 in canada from what I have seen.
I use both the first thing I do is puffer then AB then sensor klear if the dust persists. I used a wet clean the first couple of times on my 5D and it does not need it now. I suspect some 5Ds had a bit of oil on the sensor and so attract dust. The wet clean would remove oils. The oils would be bad for an AB.
2,153 views & 0 likes for this thread, 8 members have posted to it.
1014 guests, 107 members online
