Thread started 20 Oct 2008 (Monday) 09:40
Reflection
TheExpertAmateur
Oct 20, 2008 09:40 |  #1
I was driving around this weekend and found myself on a road that was overlooking a powerplant. I got my equipment out just in time to get a picture with the train coming in. I did some selective blurring for the tilt shift effect. Opinions?
Galleries - http://www.theexpertam​ateur.com (external link)http://blog.theexperta​mateur.com (external link)
kirkt
Oct 20, 2008 12:38 |  #2
The blurring definitely made me think you shot a miniature model railroad until i studied the detail of the power plant and the background a little more closely.
Kirk
jonklein611
Oct 20, 2008 12:43 |  #3
Maybe blur the other way? keep the train in focus and blur the plant a bit?
Camera: Rebel XTi, 18-55, 70-200 f/4 L, Lowepro Slingshot 200 AW, Lowepro Lens Case 2
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Oct 20, 2008 12:44 |  #4
I think the blur works well enough here to produce the "scale model" effect :)
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
scslmd
Oct 20, 2008 13:11 |  #5
For that model look, you typically see an almost complete blur in the background... a good boken. Maybe more blur in the upper 1/3 of the frame but mask the chimney pipes so they're still sharp.
5D2, 40D+BG-E2, Tamron 28-75 f/2.8, EF-S 17-55mm (kit), EF 28-135mm, EF 17-40 f/4, EF 24-70 f/2.8, EF 70-200 f/2.8 IS, 430EX, 580EX II
TheExpertAmateur
Oct 20, 2008 13:25 as a reply to  @ Jim G's post |  #6
Thank you for the comments.
Thanks! That was the goal with this edit
The focus is actually on the plant, not the train, so blurring the train further helped cover this up.
For that model look, you typically see an almost complete blur in the background... a good boken. Maybe more blur in the upper 1/3 of the frame?
I will have to try this some more when I get home. Currently there is a mask on the chimney pipes, but it is hard to tell since it is blurry right around them.
kirkt
Oct 20, 2008 14:47 |  #7
I agree that you could push the effect more, with more blur at the appropriate locations, using the lens blur filter in PS, for example. I really like the tilt-shift miniature effect, it makes one think about the visual conflict between the real-life size relationships and appearance of the image elements, but the perception of those elements as miniaturized due to the visual cues within the image processing. Very cool. If done really well, i end up looking at an image and thinking "how did they get the models to be so realistic?"
I think the train is what really sells it as a "miniature", as we are all used to seeing scale model trains - so the effect works really well by appealing to what we know to convince us of the effect.
Keep at this one. It also appears that the image is very slightly tilted to the left (counterclockwise).
Kirk
Kirk
cnhoffma
Oct 20, 2008 16:26 |  #8
Haha... Kirk pointed this out (on my thread)
https://photography-on-the.net/forum/showthre​ad.php?t=588194
I like yours, what about mine?
I have a name and some gear.
spooch
Oct 21, 2008 03:57 |  #9
The reflection of the Power Plant, and the Power Plant focus & colors are great, but the train distracted me a bit, cause it's out of focus. Maybe if you've took the shoot without the train it would be nicer. did you tryed to crop it to loose the train?? or maybe blured it more? Idea with the train is nice but the blur in that part of the photo just don't go for me. try to play more with it?
Photo gallery (external link)
Don't ask what your camera can do for you,
Ask what you can do for your camera!
1,073 views & 0 likes for this thread, 7 members have posted to it.
Reflection
2778 guests, 138 members online
