At the moment I have my 580EX II with a male Screw-Lock to male Screw-Lock sync cord to go between it and my 20D.
I would like to add a second flash (a Sunpak 383) to my set-up, but don't want to go with a wireless set-up yet due to budget restrictions! I am trying to work out what adapters and cords I need to get in addition to the flash.
I want to get another Screw-Lock sync cord the same as my existing one, so any extra fittings would need to be compatible with that in my set-up. What would be the best way to take the signal from my camera to the two flashes?
From the camera end I presume the best way of connecting things would be to have a short cord leading to a splitter, then the two long sync cords leading to each flash. The 580EXII will be easy because that has a Screw-Lock connector, but on the end of the other cord I need something to go from male Screw-Lock to Sunpak's awkward plug.
The nearest I can find is this one: http://www.flashzebra.com/short_pc_sync/0054.shtml
, but it has a male PC connector instead of a female one to mate with my cord. Is it possible to get a double-ended female PC adapter to join that with the male Screw-Lock plug on my cord?
For the camera end I'm also a bit stuck on what I need to split the signal. If I get one of those three-way sync cord splitters they look as if they have got male connectors, which is no good for my cords, which would also be male. Also I'm not sure if I can use a PC adapter with Screw-Lock cords either.
This seems ridiculously complicated for the simple task of adding a second flash, so maybe I'm overlooking something.
I just want to go from my 20D to a splitter, use two male Screw-Lock to male Screw-Lock cords and connect to a flash at each end, one being a 383 (the other, a 580 EXII I already know how to connect).
Any suggestions would be appreciated.
Mike
