Thread started 23 Oct 2008 (Thursday) 04:16
580ex II just stopped working
blinded
Oct 23, 2008 04:16 |  #1
I've had my 580ex II for a little over a year now, and when I went to use it today, nothing! No sounds, no information, even the pilot light doesn't turn on. I checked the batteries but those weren't the culprit, and neither are the contacts. It's like it's just dead, which doesn't make sense because I haven't used it recently, and when I did use it, I didn't exhaust it out. And weird how it happened right as my warranty ran out (which was too short anyways - I had other appliances which are cheaper and have longer warranties). Anything I should try that I haven't? Or any advice?
gofer
Oct 23, 2008 06:32 |  #2
When you say the batteries were not the culprit, did you check ALL the batteries? The reason I ask is that with both my 580's one battery in each flash is always more discharged than the others. This suggests to me that one of the four batteries is being used to supply the control circuits of the flash while that battery plus the others used to fire the flash tube itself (if that makes any sense).
Steve.
Scott ­ McLoud
Oct 23, 2008 10:41 |  #3
IF you have checked all the batteries, made sure that there is no problems with them and that the door is closed properly then it sounds like it could be dead already. Also make sure no water or moisture has got in to the unit or battery compartment. Also check for corrosion on the back springs in the unit
Remove all batteries, and leave it sitting in a warm place for a little while, put brand new batteries in it and try that or use an external power pack. If this still does not work, i'd send it in to canon
blinded
Oct 23, 2008 10:47 |  #4
gofer wrote in post #6546054 (external link)
Yes, I checked the batteries and even put a whole new set into them. It's completely unresponsive though If you couldn't see the on/off switch, you would think it's off when it's not. I really don't know what happened to it, but I hope if I need to get it repaired it doesn't cost much. How much do you think it would be? It shouldn't be dieing anyways IMO.
Scott McLoud wrote in post #6547006 (external link)
Sounds like great quality control then.
There is no water. In fact, it sits in it's case most of the time since I don't really take pictures a lot and haven't been around water either. I did check for corrosion too, but nothing there.
This might sound like a dumb question, but what do you mean by external power pack? I thought you could only run the 580ex II with batteries.
blinded
Oct 24, 2008 11:52 |  #5
All of a sudden it's working now! I was right on the phone with Canon and before I even got an answer, it turned on! I forgot that I didn't have batteries in it and so I put a pair in and it worked! What the hell!? I didn't do anything else with it for this to happen either. I suspect it might be the contacts, but those were one of the first things I checked when the problem started. They look really clean, the batteries are clean, and the door closed as it should, so I don't know what prompted this. Lets hope it doesn't come back again.
m3rdpwr
Oct 24, 2008 13:06 |  #6
blinded wrote in post #6553384 (external link)
Loose or bad contact? Moisture? Thermal fuse?
Who knows.
Since it's out of warranty, I wouldn't worry about it too much as long as it works...
-Mario
Scott ­ McLoud
Oct 24, 2008 18:46 |  #7
blinded wrote in post #6547047 (external link)
Not a dumb question atall :)
External battery pack is basicly where you have a cable going to your flashgun from the pack
Something like this
http://www.whcamera.co​m …pactbatterypack​cp-e4.aspx (external link)
Thats one of many you can buy. I use one everytime, becuase it not only makes the flashgun last longer (not to have dead batterys and have to change them as often) but the recharge time is alot quicker too :)
3,287 views & 0 likes for this thread, 4 members have posted to it.
1065 guests, 101 members online
