Thread started 21 Feb 2005 (Monday) 19:26
Daylight motion shots
Nabil-A
Joined Dec 2004
Feb 21, 2005 19:26 |  #1
Was wondering if anybody could give me some advice on what type of ND filter id need to be able to set a shutter speed of between 2sec 1/2 of a sec. Im trying to shoot motion shots in mid daylight at iso50. Note i think the nd filter on the G6 is about 2stops but its not enough.
Based on the F16 sunny rule, at f16, and iso50, shutter speed should be 1/50 of a sec. So since G6 is only at f8 maximum that is 2 stops more light so shutter speed will be 1/200. Is it possible to mountre ND filters to bring the shutter speed down to 1 or 2 secs while aperture is f5.6-f8?
Any suggestions. 1) Id seriously like to get 2sec or so in using the internal ND filter on the camera with an add on filter and hence get a slow shutter speed. 2) when the ND filter is attached but the internal ND Filter is off slow but slightly faster shutter speed
After specifics in ND stop amount required.
http://www.photography​bynabil.com (external link)
http://www.designerpor​traits.com.au (external link)
http://www.lovestories​photography.com.au (external link)
sdommin
Joined Dec 2002
Feb 22, 2005 06:16 |  #2
The ND filter on the G-Series is actually 3 stops. Even with that, its pretty tough to get the kind of shutter speeds you're looking for in daylight using just the built-in filter. The photo below was taken with the built-in ND filter in bright daylight that was "filtered" by trees. The best I could do was 1/8 sec. at f8.
This one was taken on a cloudy day and all I could go down to was 1/6 sec. at f8.
So I guess the lesson is that you would need an extra ND filter to get the couple of f-stops that you're looking for. What kind of thing do you want to shoot?
Scott
http://www.pbase.com/s​dommin/favorites (external link)
dewmuw
Joined Jul 2002
Feb 22, 2005 06:38 as a reply to  @ sdommin's post |  #3
One of the advantages of living in the UK is that we get a lot of cloudy days! This was taken 1 sec at f8. I used the built in ND - but was also under a lot of tree cover.
Damian Waters
www.drumimages.co.uk (external link)
Nabil-A
Joined Dec 2004
Feb 22, 2005 14:58 as a reply to  @ dewmuw's post |  #4
There great photos.
The kind of photos i was looking at creating included
1)motion city shots with the hussle and bussle of local commuter and pedestrian traffic.
2)and wildlife / nature based shots like the water photos presented below. Except being able to do motion shots on a bright sunnys day is what im trying to achieve which would then give me extended shutter speed capabilities on cloudier days.
Thanks for the example photos, so ill probably need an ND filter with another 3 - 4 stops, do you agree?
Jon
Joined Jun 2004
Feb 23, 2005 09:38 |  #5
Yes, at least 4 stops. Assuming "sunny 16", you're at f/8 1/200 with nothing, f/8 1/30 at 3x ND built-in, and you'll need 4 more stops (ND value of 1.2 = ND4X) to get to 1/2 sec. (1/15, 1/8, 1/4, 1/2.)
Jon
Cocker Spaniels
2,456 views & 0 likes for this thread, 4 members have posted to it.
2459 guests, 122 members online
