Thread started 29 Oct 2008 (Wednesday) 08:34
POLL: "Which macro flash for the MPE-65"
Canon Twin Lite MT-24EX
22
91.7%
Canon MR-14EX
2
8.3%
24 voters, 24 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
Which flash for MPE-65 ?
devil350
Oct 29, 2008 08:34 |  #1
Hi all,
I'm in the market for the famous MPE-65.
After using the Canon 100mm Macro for years, I can't resist on geting closer to the subjects...
My questions are:
- Which flash would you advice for this lens, the ring flash or the twin flash ?
And why ?
- I often seen the twin flash with diffusers on the flash, are they usefull ?
Which brand (if many) would you advice me if needed ?
I don't know very well this very specific lens, but I read many times, that it must be couple with a flash to go closer than 1:1.
Thanks in advance for your help.
Regards,
Laurent.
MY Gear List | My Gallery (external link)
racketman
Gallery: 20 photos
Oct 29, 2008 10:03 |  #2
I have both and would argue that the MT-24 at its best gives the most pleasing results. The MR-14 gives more consistently accurate exposures and is a more compact unit but the lighting is a bit flat even with ratio adjusted and diffusing applied to the tubes. The MT-24 definitely needs diffusing as it is way too harsh with the crop cameras - better with a FF sensor I have read although not got around to trying.
LordV uses a diffused 430ex on a bracket which should be food for thought.
Toby
macro ­ junkie
Oct 29, 2008 18:33 as a reply to  @ racketman's post |  #3
your need a diffuser for the mt-24ex
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
devil350
Oct 30, 2008 14:22 |  #4
Hi,
Thanks all for your comments.
Which diffusers would you advice me ? Is there a specific brand you're using ?
Bye,
Laurent.
Ook
Oct 31, 2008 08:47 |  #5
devil350 wrote in post #6592527 (external link)
Hi,
Bye,
Laurent.
Most use Gary Fong Puffers, or an eBay knockoff of that. Gluing is required.
John-Allan
40D | 11-16mm f/2.8 | 17-55mm f/2.8 IS | 100mm f/2.8 macro | 430ex | A650IS
devil350
Nov 03, 2008 02:11 |  #6
Hi Ook,
Thanks for the answer, I'll have a look at those Diffusers.
Anyone has any other advices for the right flash for MP-E65 ?
Or should I conclude the best gear is the MT-24EX ?
Thanks in advance.
Laurent.
macro ­ junkie
Nov 03, 2008 03:24 |  #7
Ook wrote in post #6597250 (external link)
Gluing is required.
no its not..racketman used the brackets that come with it..up to you i guees..i use hot glue gun because its easy to peal off..dont use super glue ffs :lol:
devil350
Nov 03, 2008 04:41 |  #8
macro junkie wrote in post #6613280 (external link)
Ok Thanks.
Off course I'll use easy to peal glue, I don't want to destroy my expensive flash unit.
Ciao,
Laurent.
macro ­ junkie
Nov 03, 2008 09:50 |  #9
devil350 wrote in post #6613408 (external link)
Ok Thanks.
Ciao,
Laurent.
super glue :lol: then 2 months down the line you have found some better defusuers..lol.what a nightmare that would be.:lol:
devil350
Nov 03, 2008 14:03 |  #10
macro junkie wrote in post #6614588 (external link)
LoL
Yes this sounds like a nightmare :D
ben_r_
-POTN's Three legged Support-
Nov 07, 2008 23:15 |  #11
The Canon MT-24EX is the only option IMO.
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Nov 08, 2008 07:45 |  #12
I use and vote for the twin flash. Of course excellent results can also be had with a flash on a bracket as Brian V demonstrates so well.
Quite apart from the lighting and modelling control advantages of the twin flash over the ring flash, it also has the advantage of less intrusive highlights and being able to turn on the focus assist lights via a double tap on the shutter button (a flash CF).
Macrophotography by LordV
macro ­ junkie
Nov 08, 2008 13:15 |  #13
Lester Wareham wrote in post #6647091 (external link)
what diffusers are you using?
Lester ­ Wareham
Moderator
Best ofs: 5
Nov 08, 2008 13:19 |  #14
Stofen, they still permit the focus assist lights to work, seem to soften the highlights well. Works better in real life than in controlled tests - so much for the scientific method....
devil350
Nov 09, 2008 03:53 |  #15
Thank you all for your comments.
Lester which Stofen do you use with MT-24EX ?
Bye,
Laurent.
3,261 views & 0 likes for this thread, 7 members have posted to it.
1338 guests, 136 members online
