I was quite happily using ArcSoft RAW Thumbnail Viewer up until the 50D and now it does not appear to work with the 50D CR2 files.
Has anyone else had this problem (or is it just me) and is there a RAW viewer that works with the 50D ?
CB357 Member 114 posts Joined Sep 2007 Location: Sydney, Australia More info | Oct 29, 2008 23:03 | #1 I was quite happily using ArcSoft RAW Thumbnail Viewer up until the 50D and now it does not appear to work with the 50D CR2 files. 1D X, EF 24-105 f/4 L IS USM, EF 70-200 f/2.8 L IS II USM, EF 100 f/2.8 L macro, EF 17 -40 f/4 L, EF 50 f/1.2 L, 600 EX RT x 2, ST-E3 RT
brownbugger Senior Member 941 posts Joined Feb 2008 More info | Oct 30, 2008 05:04 | #2 use the eos utility software Gripped Canon 50D, Canon 400D with BG-E3 Grip, 580 EXII Flash, Canon EF 24-70mm f/2.8 L , Canon EF 70-200mm f/2.8 L / Tokina 11-16mm f/2.8 /Canon EF-S 18-55mm f/3.5-5.6 / Tamron AF18-200mm F/3.5-6.3 XR Di II LD
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 30, 2008 05:10 | #3 I imagine Arcsoft updates the viewer periodically to extend support to new cameras, although there might be a bit of a lag. Why not ask them? Elie / אלי
| Latest registered member is Mihai Bucur 1436 guests, 114 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
