Is seems that AF doesn't work with my 40D + 1.4x TC with 100-400. Do others have this feature also?
But AF does work well with 40D+1.4TC+500. Is this because the 500/f4 is a faster lens or the AF system in the 40D?
sagebrush Member 158 posts Joined Dec 2001 More info | Oct 30, 2008 10:38 | #1 Is seems that AF doesn't work with my 40D + 1.4x TC with 100-400. Do others have this feature also?
Kuma Senior Member 996 posts Joined May 2007 Location: The Igloo spirit remains More info | Oct 30, 2008 10:41 | #2 sagebrush wrote in post #6591145 Is this because the 500/f4 is a faster lens or the AF system in the 40D? Yes. The AF on a 1D series would still work I believe.
nate1280 Member 53 posts Joined Sep 2006 Location: Ontario, Canada More info | Oct 30, 2008 10:42 | #3 On a 40D, you lose auto focus on lenses slower the 5.6. So the 500 f/4 w/ 1.4x TC gives you 5.6, so AF remains active. Where as on the 100-400 its 4.5-5.6, so adding 1.4 to this will be slower then 5.6, causing a loss of AF. EOS 1D Mark III, 24-70/2.8L, 70-200/4L IS, 100-400/4.5-5.6L IS, 430EX II, 055XPROB w/ 488RC2
Thanks all for you reply.....Sagebrush
| Latest registered member is Mihai Bucur 1212 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
