Thread started 23 Feb 2005 (Wednesday) 13:52
Polarizer and IR Filter
Ranger187
Feb 23, 2005 13:52 |  #1
I have the PRO1 and I'm looking for a 58MM Polarizer (I plan to use them on the 20D). Then after looking noticed there are a few different types of Polarizer and IR filters.
I plan on getting a Hoya Filter, but I dont' want to get one and then find out, "Man, you should have gotten this one" that's quite annoying... And I don't like to throw money away.
And for the IR filter, I just want the standard black / white type #89B (R72) <--- That looks to be the correct one, and the most common. Am I correct?
Below is a picture I took recently in a Cave testing some settings before I go back to take more....
I'm looking to reduce the "hot spots" of the lights. Do I just need a standard Hoya Polarizer and that's it? I noticed they have:
1. Standard
2. HMC
3. Ultra
4. S-HMC
Should I be going for the SHMC?
BLOG (external link)
[Canon A75][Canon Pro1][Canon EOS-70D] | GEAR
Jon
Joined Jun 2004
Feb 23, 2005 14:10 |  #2
You want at least the HMC multi-coated filter, to minimize reflections and light loss. I seriously doubt that you'll be able to polarize the bright spots out - they all appear to be from the cave lighting, and a polarizer won't do much for a direct light source.
Yes, an 89B/Hoya R72 is the correct filter for IR, but expect l-o-o-n-n-n-g exposures. Tou've probably already got an IR-screening (blocking) filter in your camera.
Jon
Cocker Spaniels
Ranger187
Feb 23, 2005 14:18 as a reply to  @ Jon's post |  #3
So how do I correct those bright spots then? Those just ruin the pictures and I don't want them....
Jon
Joined Jun 2004
Feb 23, 2005 14:24 |  #4
Either very careful framing to screen them as much as possible, or by doing some PhotoShop work. If these are fixed lights, you'll have to live with them. If the owners of the cave will permit, you may be able to put some polarizing material over the lights and use a polarizer on the lens to cut down the intensity, but that's also going to seriously impact the available light for photography. If they're movable, you'll have to be careful where you set them up.
Jon
Cocker Spaniels
Ranger187
Feb 23, 2005 14:29 as a reply to  @ Jon's post |  #5
I have free reign of the cave. But moving the lights is not one of them. I will get fined $20,000 per rock touched on any "live" wet rock... So I don't think that is an option. ;)
I was under the impression a Polarizer filter on the camera would cut this down. How would I go about correcting in Photoshop?
Jon
Joined Jun 2004
Feb 23, 2005 14:42 |  #6
A polarizer will only cut down reflections. As you're dealing with irregular surfaces and included light sources, there's not a lot of polarized light to deal with. In PhotoShop, you could make a negative mask and gradually thin it to allow the darker areas to show through while holding back the brighter ones.
Jon
Cocker Spaniels
1,871 views & 0 likes for this thread, 2 members have posted to it.
1051 guests, 105 members online
