Thread started 30 Oct 2008 (Thursday) 21:53
benefit of shooting at lower mp with the 50D
elitejp
Oct 30, 2008 21:53 |  #1
this is somewhat in response to the dpreview on the 50D and this forums response to the 40D and 50D noise comparisons. One argument is that the 50d has too many mp making it noisy and not really worth the upgrade noise wise. Now what if you shot at 8mp instead? Would that help out the noise? If people really arent concerned about mp than this should be a great solution if it works.
6D; canon 85mm 1.8, Tamron 24-70mm VC, Canon 135L Canon 70-200L is ii
Superficialodds
Oct 30, 2008 21:59 |  #2
The only difference you will come away with, is a smaller image. Reducing the image size wont effect the amount of noise.
elwood58
Joined Dec 2004
Oct 30, 2008 23:09 as a reply to  @ Superficialodds's post |  #3
Noise tends to be a factor of how small and close together the pixels are. The pixels coerce each other. As the ISO goes up, the sensor heats up and the coercion increases to the point of creating noise that is very visible.
The only way to achieve less noise is to have larger pixels and more space. As the sensor is a fixed size, the high pixel count works against you.
50D and a bunch of lenses (external link)
nick400d
Oct 31, 2008 00:09 as a reply to  @ elwood58's post |  #4
What does the pixel binning do then?
only activate half the pixels (roughly) making the image roughly 8mp? Or does it let pixels merge (since their gapless microlenses) to create an 8mp image with larger pixels than the 15mp image?
Canon 7D - Tokina 10-17mm Fisheye - SIGMA 24-70 2.8 ex - Canon 70-200mm F/4L - 50mm f1.8 - 430ex flash - 2 Vivitar 285hv's
Nicholas Bucher - 17y/o - Sydney, Australia
1,195 views & 0 likes for this thread, 4 members have posted to it.
1518 guests, 132 members online
