Thread started 31 Oct 2008 (Friday) 02:17
First Sports Motion Pictures
alkyoneus
Oct 31, 2008 02:17 |  #1
First off, I'm a total newbie to this, I originally purchased my Cam for work purposes, but I could not resist taking some action shots of my friends playing paintball.
Its a rebel XTI with a Tamron 17-50 f2.8 ld xr lens
The only options I put where on the sports/motion settings. None of the pictures where edited, just a few were cropped because the shield/cover I was using to protect my mask came into the picture.
I need some guidance with the settings I guess, as most of them came out a bit blurry, gotta start somewhere right.... :oops:
Let me know how I could improve them.
Here is the link to my album (external link)
http://picasaweb.googl​e.com …Pball?authkey=j​rKFbQsxFLU (external link)
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Oct 31, 2008 02:40 |  #2
I think you might want to invest in a lens with some additional length that will allow you to get into the action more
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
0ozma
Oct 31, 2008 07:51 |  #3
Agree with above, and I think most of them could have been improved by a higher shutter speed. I never really use the action setting, just crank the shutter speed to stop motion and adjust elsewhere (iso, f-stop) until the meter reads correctly. I don't see any EXIF data attached so I can't really tell what they were shot at though.
Canon 50D | Canon EF 50mm F/1.4 | Canon 70-200mm F/4 L | Canon 17-55mm F/2.8 |
Save $5 on a new Zenfolio account using this code:
3P6-72F-UB8
Nathan
Gallery: 18 photos
Oct 31, 2008 11:30 |  #4
btw - I like this shot very much... I'd recrop it, however.
http://picasaweb.googl​e.com …sxFLU#526319448​5236582242 (external link)
alkyoneus
Oct 31, 2008 15:42 |  #5
0ozma wrote in post #6596995 (external link)
can you tell me how to do this?
Laramie
Still livin' the cowboylife
Oct 31, 2008 21:37 |  #6
Put the camera dial on Tv and select a shutter speed like 1/500 or so. Your Tamron is a great lens.
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
babos02
Nov 01, 2008 14:12 |  #7
did you use any type of shield to protect your camera? i would love to photograph paintball but i dont want my camera to be hit by a stray ball?
ABABS
http://www.photobucket​.com/babos02 (external link)
dkord
Nov 02, 2008 01:43 |  #8
Before you start taking all these sage advice.
Look at your photo info: learn how to break down your mistakes.
400 iso = 1/25 of a second at 2.8.
Break that down: At f/2.8...
400 iso = 1/25
800 iso = 1/50
1600 iso = 1/100
3200 iso = 1/200
6400 iso = 1/400
Not sure how well your XTi will do at 6400 iso if it can do it naturally. Those underexposed shots will give you a lot of banding.
Bring a flash with you if you can, it syncs at 1/200, and you can shoot at 400 iso. If you shoot in manual, you can cheat a little and probably get away with 1/300 of a sec with little shutter shadow at the bottom of your screen. Not as noticable when you shoot around 50mm, instead of 17mm, it'll also fix the issue with subjects being so small.
Speaking of 50mm, think about using a 50mm 1/8 if you want to shoot with out flash (they are relatively cheap) so instead of that 6400 iso you can probably dial in a noisy 3200 iso if you want to shoot at 1/400.
But looking at most of your shots 1/200 at f1/8 with 1600 iso will cover a lot of your stuff. If your subjects move, learn to pan with them or Get a flash.
The devil is in the details...Especially at 100% crop!
https://www.flickr.com​/photos/eosdawg/ (external link)
Croasdail
making stuff up
Gallery: 19 photos
Nov 02, 2008 10:24 |  #9
I would go much tighter on the crop. Shooter is lost in the shot. On the shutter speed, you all know what shutter speed you need to capture a good paint ball splat?
alkyoneus
Nov 02, 2008 23:41 |  #10
Here is round #2, I opened it up 2.8 and put iso 1600 and put the white balance to flourecent lights, pictures came out wayyy better!
what do you guys think?
http://picasaweb.googl​e.com/tomaspossenti (external link)
dkord
Nov 03, 2008 00:50 |  #11
Nicer, better crops for the most part too. Some of those wides are nice for overviews but I do prefer the tighter crops. It looks like you're shooting from a standing position, you might want to try some lower angles.
At 1/100 sec you notice that your exposures are nice but you're still struggling with motion?
At 1/200 sec, it's a tad underexposed and at 1/400 ( your wides) the subjects are almost vignettes.
Remember the meter gets fooled by the back lighting and over head lights. If you want more consistent exposures, you might want to consider shooting in Manual mode. You have to decide what to sacrifice, slight under exposures, better motion control or good exposure with motion blur.
You're getting the hang of it, nice improvements.
alkyoneus
Nov 03, 2008 01:19 |  #12
dkord wrote in post #6612932 (external link)
thanks, what settings should I use in manual mode?
Can you tell me what to change?
Nathan
Gallery: 18 photos
Nov 03, 2008 01:35 |  #13
Alky - I am not sure if anyone can simply tell you what settings to use. Each environment will require a different group of settings. Once you give it some practice, you'll start to develop a sense of what you'll need. When started, I read up on all sorts of articles and I was experimenting simply by photographing people walking and kids playing. However, my first shots of our martial arts classes were particularly disappointing. Despite what I knew technically, it was practice that allowed me to be able to improve.
Logan2010
Nov 03, 2008 16:35 |  #14
have you tried laying on the ground ? when shooting paintball its best to lay and make sure you know exactly where everybody is.. that way you can get the best angles without getting a stray ball. use a very thick filter for it will protect your glass in your lens (70 mm + ) also, invest in a lens with a greater focal length. it will help alot. and if your worring about getting oily paint all over your camera ive found that you can take a sock and cut a hole in one end and it will cover your entire camera very well.. and your screen will still be visible.. you just have to memorize where all your buttons are.
logan
dkord
Nov 04, 2008 17:10 |  #15
alkyoneus wrote in post #6613003 (external link)
Look at your photo's and the exposure info.
I already discuss your shutter speed settings: shooting at f/2.8 and 1600 ISO if those two variables are not changed, your photos should give you an idea what the shutter speed should be set to. Higher the shutter speed gives the best chance of stopping action, too high and you're too underexposed.
Fortunately for you the lighting doesn't change unless you go wide or shoot against those windows. But those two variables don't actually affect true exposure on your subjects but it can fool your meter, that's the key to shooting manual: you're not dependent on the meter so your exposure will not fluctuate.
If you can try shooting RAW, you'll loose some buffer and the ability to shoot a long burst, but it least you shoot a bit underexposed.
I hope those hints will help you but I'm not going to tell you your setting, it's about figuring out your mistakes and improving as a photographer.
I know you'll figure it out.
1,949 views & 0 likes for this thread, 8 members have posted to it.
1644 guests, 174 members online
