Thread started 31 Oct 2008 (Friday) 12:13
M45 from Chiefland Florida.
markjpcs
Oct 31, 2008 12:13 |  #1
IMAGE: http://www.pcsincnet.com/M45102608-1Rev3.jpg
Canon 50D
Astro-Physics 105mm APO f5.8
134 x 1 minute exposures stacked and median combined in Deep Sky Stacker.
10 dark frames median combined into a master dark and subtracted in Deep Sky Stacker.
Post Processing in Photoshop CS3
Astro-Photo Web Site. http://www.bigcigarast​ronomy.com (external link)
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Oct 31, 2008 12:16 |  #2
:shock: :shock: :shock:
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
Nighthound
Gallery: 224 photos
Best ofs: 24
Oct 31, 2008 13:00 |  #3
Looking good Mark, wish I was there. I'm going to our dark site tonight on the ocean. Looking to get the California Nebula.
Hope you have a great time there.
Steve
Celestron
Nov 01, 2008 00:43 |  #4
Great shot ! You just need to edit that green background . WTG and thanks for posting !
Adrena1in
Nov 01, 2008 12:30 |  #5
Lovely. Try as I might I simply can't extract any of the nebulosity from my M45 photos, so I'm always impressed at shots like this.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
markjpcs
Nov 02, 2008 00:02 |  #6
I toned down the Green curve a bit.
IMAGE: http://www.pcsincnet.com/M45102608-1Rev4Reduced1024.jpg
Johnny9s
Nov 02, 2008 01:38 as a reply to  @ markjpcs's post |  #7
The edit look great. bw!
My flickr page (external link)
Canon 7D, Canon 40D, Canon 10-22mm, Canon 50 f/1.8, Canon 70-200 f/4L IS, Canon 100mm Macro, Canon 400 f/5.6L, Canon 1.4TC, Canon 580 EXII, Better Beamer, Sky-Watcher 12" Collapsable Dob
https://photography-on-the.net/forum/showthre​ad.php?t=586230
Celestron
Nov 02, 2008 15:25 |  #8
Mark , this is more like what i was talking about with the green . On my computer it's a solid green background even in your re-edit . Hope you don't mind my reposting it . I had to reduce the file size also because of 150K being max for this section on image size .
ebann
Joined Jan 2003
Nov 02, 2008 16:52 |  #9
Where did the green cast come from?
Ellery Bann
Fuji X100
markjpcs
Nov 02, 2008 17:50 |  #10
Ron,
Thanks it looks much better!
I see it now. It is more obvious on my laptop though.
What did you do to fix it? I just brought the green curve down a bit.
I'd like to apply your edits to the original tiff file.
Mark
Nighthound
Gallery: 224 photos
Best ofs: 24
Nov 02, 2008 18:38 |  #11
Mark,
I took a look at your image in Photoshop and a few things jumped out. The saturation level looks a bit high on my monitor so I backed it down a bit. Also the color balance was off so I tweaked it and raised the black point a bit to see if there was any faint detail being masked. Because this is a low rez JPEG I can't bring back what was lost in the original but take a look in the circle in this image and some detail was revealed even at this stage. These DSLRs are great but when it gets down to the faintest of details I find myself really working hard to retain it during the last stages of processing.
Hope you don't mind me tinkering and sharing some thoughts. Hope you had a great time at Chiefland.
IMAGE: http://i3.photobucket.com/albums/y67/Nighthd/Astrophotography/test/tst2/M45102608-1Rev3nh.jpg
Steve
R ­ Hardman
Nov 02, 2008 19:13 |  #12
Mark, love the details!
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert (external link)
Celestron
Nov 03, 2008 08:28 |  #13
markjpcs wrote in post #6610623 (external link)
Ron,
Mark
Mark the first thing i do is open LEVELS and click the gray point dropper button , move the cursor over to a dark section of the image (Usually middle upper left hand section ) and right click . You will notice an overall change in the cover haze a picture has on it . This helps remove some false LP film but becareful cause it can also cause a sky change in color . Play with this before you save it to adjust it to your likings . As Steve mentioned he toned down the saturation and i agree it was a little too much but i didn't want to change too much in case you didn't like it but Steves version is better . Next i will check the histogram and see if things are still ok . Next i will make adjustments in VARIATIONS . If it looks ok i'll save a copy first and see how it looks when opened . If the background isn't dark enough for me then i'll use SELECTIVE COLORS and adjust Black point and maybe NEUTRALS point . Careful on the NEUTRALS tho cause one # too much can cause lost of detail and same as with the Black Point adjustments . One main thing i try to watch is to not disturb the Histogram very much . I have a hard time with this . Some times i knock it way out of whack and i'll have to start all over again . I never save any adjustments to the original image cause once saved you cannot go back to the original image and if you don't have a copy then your out of luck to start from scratch again :( .
markjpcs
Nov 03, 2008 12:04 |  #14
Thanks for the processing tips!
Here is my latest revision based on your (Ron and Steve's) advice.
IMAGE: http://www.pcsincnet.com/M45102608-1Rev5_72dpi_1024.jpg
I could play with this all day but I have real work to do. :lol:
It looks like I captured a faint galaxy to the right of M45! I love it when that happens! ;)
ebann
Joined Jan 2003
Nov 03, 2008 12:07 |  #15
markjpcs wrote in post #6615403 (external link)
Niiiice!!! bw!
Ellery Bann
Fuji X100
4,490 views & 0 likes for this thread, 10 members have posted to it.
1028 guests, 159 members online
