Thread started 01 Nov 2008 (Saturday) 00:15
20d shutter problem, details inside
turnmybassup
Nov 01, 2008 00:15 |  #1
I am sure that I'm beating a dead horse here, but I bought a used and broken 20d that was doing the rapid firing thing that is very common among these cameras. I then bought the shutter switch that is highly recommended as the repair, tore the camera apart thanks to doug kerr's fabulous diy, put it back together and . . . nothing changed.
So, I'm wondering what else might be wrong?
When the battery is inserted it fires a couple actuation's, then if you bump it it will stop, and this is all in the off position.
Then if you turn it on, it will do one of two things (all while rapid-firing the shutter).
1. it will flash "no cf" and have normal display for a split second and then go to the flashing battery symbol
2. it will flash "no cf" and the normal display, then start to flash err 99.
It is entirely possible that I didn't get my soldering good enough on the switch but I'm pretty darn sure that it was good; what else typically goes wrong in these that might be DIYable?
I'm trying to avoid sending this to canon, but I suppose I will if I have to eventually.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Nov 01, 2008 04:28 |  #2
almost everything's DIY-able, just need enough care not to break stuff while you're doing it.
I suspect you may need one of these: http://www.sdcamerasol​ution.com …p=product&id=66​&parent=25 (external link)
TF posting: here :-)
turnmybassup
Nov 01, 2008 21:02 |  #3
well I suppose that is true about everything being a diy project, I'm just wondering how hard THAT will be . . .
1,387 views & 0 likes for this thread, 2 members have posted to it.
1502 guests, 133 members online
