Thread started 02 Nov 2008 (Sunday) 23:24
Post-processing help for skin tones...
tnicol
Nov 02, 2008 23:24 |  #1
It seems like the last two or three of my outdoor portrait sessions have had one person with really white skintones that wash out badly. To fix it in ACR leaves the rest of the image seriously dark, including the more "normal" second person. Does anyone have any advice? Fill flash makes it worse. This example is from this weekend, no flash, cloudy overcast skies. Thanks for any words of wisdom.
IMAGE: http://tnicol.net/potn/IMG_9747.jpg
Tom...
http://www.tomnicolpho​tography.com (external link)
http://tnicol.blogspot​.com (external link)
rjc1
Nov 02, 2008 23:39 |  #2
This has happened to me before, I am very basic with PS7. I did a selection with the lighter face and adjusted the briteness/contrast on it, it worked OK but I will bet there are much better ways!
40D with 28-135 IS , Tamron 17-50 ,100-400 f4.5-5.6L, 100mm f2.8L macro IS, 430EX, 430EXll,MiniTT1/FlexTT​5 , Kata R-103,
Domke F2 shooters bag
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 02, 2008 23:56 as a reply to  @ rjc1's post |  #3
You should develop an organized workflow and learn proper application of each of the ACR adjustments. First you need to do a white balance. In the sample image, it appears that you have added way too much saturation and contrast. Also, the huge amount of Recovery adjustment implies that highlights were severely blown out, in which case, the recovered image will never be as good as a proper exposure. The book, "Real World Camera Raw" by Bruce Fraser is an excellent text for learning the nitty gritty of ACR.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 03, 2008 00:40 as a reply to  @ Bill Boehme's post |  #4
If you would like to see an edit of the image, turn on the "IMAGE EDITING OK" permission in the user control panel.
tnicol
Nov 03, 2008 08:26 as a reply to  @ Bill Boehme's post |  #5
Thanks very much Bill. You're right, I tried a lot to save this and similar images, mostly as the result of the light skintones. I turned on image editing so feel free to have at it. I appreciate any help you can give me.
Tom...
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 03, 2008 10:39 as a reply to  @ tnicol's post |  #6
I decreased the exposure and contrast in this edit. I also decreased the saturation considerably. I also created a new layer in which I lowered the brightness and exposure on the man's face. My main objective was to lower the strong contrast and color saturation in the faces. I did not concentrate as much on the clothing and background, so they might not have the correct amount of exposure or brightness, but that could easily be changed by creating adjustment layers.
hawkeye60
Nov 03, 2008 10:52 |  #7
I created a solid color adjustment layer set to color mode, and painted over his face. The a second with a little red added in certain areas. Not perfect, but you'll get the idea.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
shannyD
"...in too much trouble"
Nov 03, 2008 11:26 |  #8
on the first edit.. i did a color burn on a new layer.. got it as close to brown as i could.. set the opacity, and fill to about 50% adjusted highlights a little. and thats that.. on the second one.. i did the same thing.. but on the forehead i samled the skin that was not blown out, added it to around the hairline. then smoothed it out a little.
original
IMAGE: http://i28.photobucket.com/albums/c239/daisydeadpeddles/getatan.jpg
first attempt
IMAGE: http://i28.photobucket.com/albums/c239/daisydeadpeddles/getatanc.jpg
second attempt
IMAGE: http://i28.photobucket.com/albums/c239/daisydeadpeddles/getatanc2.jpg
tnicol
Nov 03, 2008 13:41 |  #9
Bill, Hawkeye, and Shanny. Thanks very much for your help. I'll try suggestions when I get back to it tonight. Now my big worry is what to do for their wedding when I have dozens like this. Yikes! Thanks again.
Tom...
sgogula
Nov 03, 2008 13:46 |  #10
shannyD wrote in post #6615164 (external link)
I liked the second edited image. Could you elaborate how you did the second image or any link to the tutorial to achieve this would help. Thanks
how do you sample the skin?
Canon 5D III | Canon 24-70 L II | Canon 50D | Canon 70-200 2.8 L IS II | Sigma 17-50 OS | Canon 50mm f1.8 II | 580,430 EX II Speedlite
shannyD
Nov 03, 2008 14:08 |  #11
tnicol wrote in post #6616019 (external link)
tell him to go to a tanning bed for the month before.. on a low setting.. ( only kidding of course)
sgogula wrote in post #6616060 (external link)
on his forhead where there was still skin color available.. i used the clone tool, and started moving my way up to the hairline sampling, and blending as i went on... i did this to make sure i wasnt too splotchy.. on a full resolution photo it would have been better.
then from there i had a free plug in for skin smoothing for PSCS3. and used that just to soften my trail so it wasnt as noticeable.
the color burn.. go to layer/new fill layer ( click ok) then it brings up he area where you can choose a color, i chose what i liked. from there it turns your whole page that color that you chose.. from there where all of your layers are.. click on the bending options, and click on color burn. it will look really dark and contrasty..
from that point.. move your fill slider to your taste, and the opacity slider to your taste.. i chose a 50/50 blend.
and all of this was done on a seperate layer so i dont mess up the original.
no tutorial.. i pick up info as i read on the forum, and write it down.
shannon
Peano
Nov 03, 2008 14:49 |  #12
My hunch is that this could be fixed better with two "exposures" in ACR, one for the man's face, the other or everything else.
But starting with your posted image, I first added a blank layer, changed blend mode to linear burn, painted on skin tones (sampled from the woman's face), masked out everything but the man's face, then adjusted layer opacity. Above that I also made a slight levels adjustment using the same mask (just pulled in the left-hand slider to darken the face a tad more).
Result:
Peano
RadiantPics.com (external link)
Sorarse
Nov 03, 2008 18:21 |  #13
You could try creating a duplicate layer and applying a warming photographic filter from the image>adjustments menu. The opacity/strength of the chosen filter can be adjusted to get the right skin tones. Obviously these changes will affect the entire image, so once you have the skin tones you are happy with, you should apply a layer mask so that just the skin areas show through.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
Dawgman
Nov 03, 2008 18:36 as a reply to  @ Sorarse's post |  #14
What I do fairly often is select the highlights to a new layer and change the blending mode to "multiply". Then lower the opacity to your liking. Then mask out the section you don't want to darken. This works well for me often in skin tone, but especially in landscapes.
2,011 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is RawBytes
1541 guests, 165 members online
