Thread started 04 Nov 2008 (Tuesday) 07:41
Lightroom raw+jpeg question
John ­ E
Nov 04, 2008 07:41 |  #1
I normally take raw+jpeg shots. When I download them to lightroom it displays them as one thumbnail, raw+jpeg (unless you change the option in preferences dialog to display them as two separate thumbnails.)
I enjoy using the preference that displays the raw+jpeg as one thumnail. However, I'm confused at which one I'm actually working on (raw or jpeg), and how do I separate them if I want to. As I understand it, they are not stacked. Can anyone explain how this works! Thanks!
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
davidcrebelxt
Nov 04, 2008 12:18 |  #2
With RAW+jpg files, you are only ever editing the RAW data... the +.jpg is only really done as 'courtesy' to let you know that a .jpg version exists.
As far as I know, there isn't an easy way to seperate them. I'm not even sure if changing that option, then re-importing the .jpgs would work.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
Kronie
Nov 04, 2008 15:24 |  #3
Cant you select the info as an option somewhere and it lists the files info on the bottom? Like CR2 file or a JPEG?
919 views & 0 likes for this thread, 3 members have posted to it.
500 guests, 126 members online
