Thread started 04 Nov 2008 (Tuesday) 19:13
Is a single video 'frame' the same thing as a still photo?
HarrisonClicks
Nov 04, 2008 19:13 |  #1
I think the answer to this is "no", but say I purchase the 5DMII and shoot 10 seconds of video of a baseball pitcher pitching to a fastball hitter. If I want a shot of the ball hitting the bat, can i 'export' a single frame of video, and would that be the same as a still photo from the same 5DMII from a resolution, sharpness, clarity, exposure, etc. standpoint?
Adam
Gear List Temporarily Removed
SolidxSnake
Nov 04, 2008 20:06 |  #2
1080iAddict wrote in post #6624866 (external link)
It is technically a photograph, however, it will not be 21MP like the 5D2 takes normally. The still frame pulled from a video will be at a resolution of 1920x1080.
Resolution will not be the same, but everything else should be the same unless I'm missing something. Exposure should definitely be exactly the same if you were shooting at whatever shutter speed the camera is shooting at (a slowest of 1/60th I believe), and the rest have to do with the shutter speed and the capture (camera shake will add to a slower shutter speed).
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
mad212
Nov 04, 2008 21:42 |  #3
I assume compression will be applied in camera which may degrade quality. We will just have to see!
beezwax
Nov 04, 2008 21:55 as a reply to  @ mad212's post |  #4
no it is not...
Video is measured in Horizontal lines of resolution..
doesnt matter whether its interlaced or Progressive scan. if it's shot with anything less that 60fps (which is HD) then grabbing a still from motion will have extreme motion blur
MYGEAR
GULFCOASTTUNDRAS.com (external link)
SolidxSnake
Nov 04, 2008 21:59 |  #5
beezwax wrote in post #6625748 (external link)
no it is not...
Still is measured in Pixels
The resolution of the video is 1920x1080. Since it shoots 1080P, it's shooting at 1/60th at the very minimum, and it can expose faster than that to darken a bright scene with a wide aperture (like a normal videocam)... then again I am assuming that the 5d2 can do this but that's how most video cameras are.
1) RTFM.
2) Repeat Step 1.
beezwax
Nov 04, 2008 22:06 as a reply to  @ SolidxSnake's post |  #6
no argument here
MYGEAR
SolidxSnake
Nov 04, 2008 23:27 |  #7
One thing though, 1/30th is still HD, just not "full" HD. 1/30th is 1080i, where it would shift the vertical lines one up and one down each frame (interlacing).
1) RTFM.
2) Repeat Step 1.
liquidstone
insane Bird photographer
Nov 05, 2008 03:36 |  #8
SolidxSnake wrote in post #6625770 (external link)
Nope.... slowest shutter speed of the 5D2's movie mode is 1/30 sec and fastest is 1/125 sec.
Romy Ocon, Philippine Wild Birds (external link)
Over 260 species captured in habitat, and counting.
liquidstone
Nov 05, 2008 03:39 |  #9
The fastest shutter speed of the 5d2 movie mode is 1/125 sec, and that's too slow to freeze action.
HarrisonClicks
Nov 05, 2008 05:36 as a reply to  @ liquidstone's post |  #10
I figured the answer would be no. And I personally feel this is great news. Photography is an art to its own and filming at 29.97 fps for a "series of photographs" and then picking the best one "takes away" from the art. I am NOT saying video on the 5MKII is a bad idea - but video is its own art, and this camera will make beautiful creative video art. But its a separate art - and should be a separate art.
Adam
beezwax
Nov 05, 2008 08:03 as a reply to  @ HarrisonClicks's post |  #11
so then my simple explanation was correct?
MYGEAR
HarrisonClicks
Nov 05, 2008 19:51 as a reply to  @ beezwax's post |  #12
yup!
Adam
beezwax
Nov 05, 2008 21:44 as a reply to  @ HarrisonClicks's post |  #13
ha... well fathom that...
good luck to you
MYGEAR
Matthew ­ Craggs
Nov 17, 2008 15:25 |  #14
SolidxSnake wrote in post #6626167 (external link)
Small nit pick: HD shot at a shutter speed of 1/30 is every bit as much HD as video at 1/60. As much as a photo taken at 1/30 is as much a photo as a photo taken at 1/60, 0r 1/100, or 1/8000.
However, as mentioned above, the 5DMkII is limited in it's shutter speeds so there will be motion blur in the original posters scenario.
SolidxSnake
Nov 17, 2008 18:14 |  #15
Matthew Craggs wrote in post #6705724 (external link)
I worded that wrong. I meant that HD displayed at 1/30 (30fps/30Hz Refresh Rate) isn't "full" HD because it is only 1080i. Of course, if the video is shot at anything slower than 1/60 the frame rate could just be adapted to fit into 60Hz.
1) RTFM.
2) Repeat Step 1.
4,259 views & 0 likes for this thread, 6 members have posted to it.
1041 guests, 114 members online
